Old 08-02-2010, 10:24 AM   #1
12V power supply failure alarm
Hi,
I need a simple alarm ( buzzer) to operate when the 12V CPU fan in my incubator stops working.
A simple solderable circuit diagram and shopping list would be great. I guess I need a relay circuit and the buzzer to have a separate power supply but I need help with the layout details.
Cheers,
Neil
neildawes is offline   Reply With Quote
Old 08-02-2010, 11:31 AM   #2
zpm
yeah, right
Plug the incubator into a UPS. They have built in alarms and will keep the incubator running during short term power failures.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-02-2010, 11:47 AM   #3
VBT
VBT's Avatar
I think what your looking for is a battery monitor circuit. Here's one that should be adaptable to your needs. You would only need the relay to operate an alarm instead of disconnecting the circuit on this one.
VBT is offline   Reply With Quote
Old 08-02-2010, 12:22 PM   #4
It was a dark and stormy
Yoyizit's Avatar
I'd go with a photodiode and emitter that puts light through the blades. When the light/dark pattern stops the alarm sounds.
Another way would be a fast responding temp. detector, using a very low thermal-time-constant thermistor or temp. sensing diode.
Or a small microphone next to the upstream side of the blades; no noise = alarm.
Old 08-02-2010, 03:40 PM   #5
Semi-Pro Electro-Geek
Most CPU fans have three wires, and the yellow one provides an AC signal that indicates rotation speed. There's no need for external sensors, just read the AC voltage on this wire.
mpoulton is offline   Reply With Quote
Old 08-02-2010, 06:52 PM   #6
Hi and thankyou for your replies,
However I am still after a simple circuit that I can wire and solder together.
The circuit should sense that the power supply to the fan is not working and cause a buzzer alarm to sound.
Something along the concept in the diagram below.
Many thanks,
Neil
Old 08-02-2010, 07:53 PM   #7
Yoyizit's Avatar
Pick a 9 vdc buzzer
http://www.hosfelt.com/contents/en-us/d475.html
pick a relay with a 12 vdc coil and double throw contacts
http://www.hosfelt.com/contents/en-us/d111.html
wire the buzzer in series with the 9v battery in series with the normally closed contacts of the relay.
Old 08-02-2010, 10:04 PM   #8
There is an error in the diagram above , Sorry,
Neil
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
Arcade machine power supply runcmd3 Electrical 11 03-15-2009 07:44 PM
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
