12v Garden Lighting System Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 11:52 AM   #1
sktn77a's Avatar
Rewards Points: 392
12v garden lighting system problem
I have a Malibu garden lighting system that was "professionally" installed in Dec 2009. The floodlight at the end of the wiring circuit has stopped working. The light works fine when I connect it directly to the transformer, so I don't think it's the light. I get between 10 and 11 volts at the end of the wiring (so I think the light should work) and all of the other lights on the circuit work fine.
Any ideas?
Keith
(Oh, in case your wondering, the "professionals" no longer return calls.)
sktn77a is offline   Reply With Quote
Old 06-26-2010, 07:25 PM   #2
Rewards Points: 1,532
How many volts do you get when you connect both the voltmeter and the light to tne end of the wiring at the same time?
Does the light in question work if you connect it into the wiring at the second to last light location?
Old 06-26-2010, 08:47 PM   #3
sktn77a's Avatar
Rewards Points: 392
I recall it was about the same.
Didn't try that - as the light worked when it was connected to the transformer, and worked fine before, I figured it was OK (?)
new system install.....questions firedogut HVAC 4 10-04-2009 07:10 PM
Problem with septic drain field Patriot_RAM Plumbing 7 04-21-2009 02:55 PM
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 04:57 PM
Outdoor Lighting Hookup Problem kennykenny Electrical 4 08-31-2008 05:42 PM
