12v DC Motion Sensor...non PIR? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 08:13 PM   #1
Rewards Points: 111
12v DC motion sensor...non PIR?
Putting some ambient led lighting underneath a floating vanity in our bathroom, and while shopping for PIR sensors, came to the quick realization that the HVAC duct is about 12" off the floor...about the same height the PIR sensor would be at.
would the air (hot or cold) trigger the PIR sensor? I understand that they trigger on both temprature and motion change?
do I need to look at a different option?
redline9k is offline   Reply With Quote
Old 04-19-2013, 09:09 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,922
No. They trigger only from moving warm objects. HVAC is stationary, and will not activate it.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-19-2013, 09:19 PM   #3
Rewards Points: 111
Ok thanks. So objects with mass then huh? The hot/cold air blowing wihin the units range wont do it?
Old 04-20-2013, 01:09 PM   #4
Correct, although air does have mass. It detects moving objects emitting IR within a certain range of wavelengths, corresponding to roughly body temperature. So only objects with significant emissivity are detectable. Air is transparent, so it has essentially no emissivity, so there is no IR radiation from the air to detect. The HVAC diffuser will emit, but it's not moving around so the detector will not trigger from it.
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 02:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 08:52 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 10:39 PM
Motion flood "non-standard" wiring Fishin_Man Electrical 5 01-14-2009 03:20 PM
