12v Battery To Operate 120vdc Motor? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 05:24 PM   #1
12v battery to operate 120vdc motor?
I have a 120vdc treadmill motor that has a motor controller board and a transformer to operate it. My question is is there any way to rigg it up to a 12v deep cycle battery. I was thinking all i would need is some sort of step up transformer 9-1 if they make it or 10-1. I would aslo like to have speed control which i assume would work through lowering the voltage. It runs fine off the 12v batter just not near the rpms i need. I know it will drain the deep cycle very fast but im not worried about that.
kevin07 is offline   Reply With Quote
Old 04-23-2012, 05:27 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Step up/down transformers only work with AC, not DC.
Never could understand the need for treadmills.....running on the sidewalk if free....
The Following User Says Thank You to ddawg16 For This Useful Post:
kevin07 (04-23-2012)
Old 04-23-2012, 05:46 PM   #3
Just a DIY guy
sidewalks are hard, can't watch TV on the sidewalk, and god forbid there might be some weather outside (not in our neighborhoods, but maybe elsewhere).
M3 Pete is offline   Reply With Quote
Old 04-23-2012, 07:56 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,366
The eaisest way is to use a 12v to 120v invertor !
They are readily available,
And it is the safest way to do it,
As no modifing is needed.
dmxtothemax is offline   Reply With Quote
Old 04-23-2012, 07:58 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,942
None of that will work the way you want it to. What are you trying to accomplish? Why not use a 12V motor?
mpoulton is offline   Reply With Quote
Old 04-23-2012, 08:03 PM   #6
Never could understand running... Unless someone is chasing you with a pistol of course...
Evstarr is offline   Reply With Quote
Old 04-23-2012, 08:25 PM   #7
my buddy fishes bass tonaments and they are electric only. outboard electric motors cost a lot! im trying to get the treadmill motor to work with a pulley and a custom built drive so he can beat boats to the good spots.
Old 04-23-2012, 08:28 PM   #8
Do you mean 12vdc to 120vdc or do you mean to 120vac because if its ac i believe a treadmill pulls around 12 amps and it would have to be a 2000 watt inverter and that would be pricy trying to make it work with the lowest possible cost. There may be some cheap one though ill have to look around.
Old 04-23-2012, 09:22 PM   #9
Smile
12 volt motor
The inverter idea is probably the best, but if the motor actually runs from 12VDC, then it must be a brush motor, not an induction motor. In that case multiple battery's in series would give you more speed. Speed control could be accomplished thru a controller like used for electric bikes or golf carts (would need to be sized for load) one source of these as well as efficient DC motors is: http://www.goldenmotor.com/. Don't work for them, have just looked at their product line (including electric outboard motors), but you're correct they are quite pricey. Another speed control would be a selector switch for how many battery's are being used.
TomGourdin is offline   Reply With Quote
Old 04-23-2012, 09:47 PM   #10
Rewards Points: 150
Anybody remember Scrapeheap Challenge/Junkyard Wars?
How big of a boat are you moving?
goosebarry is offline   Reply With Quote
Old 04-24-2012, 01:51 AM   #11
Junkyard wars was an awsome show! wish it was still on.
The boat is a 14ft flat bottom with Alot of weight in it. We had 3 55lb thrust trolling motors on it last time and they beat most boats to the spots.
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 03:51 PM
replace repair fasco inducer motor myronl HVAC 4 11-19-2011 07:59 PM
Outside condenser fan motor stops tatums4 HVAC 21 10-12-2011 08:17 PM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
