12ga. Wiring For Lighting Circuit. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:38 AM   #1
12ga. wiring for lighting circuit.
Is there any reason I can't use 12ga. romex and a 20 amp breaker for a lighting circuit? I have a bunch of 12/2 leftover and would like to use it up.
MisterSteve is offline   Reply With Quote
Old 04-21-2012, 10:40 AM   #2
joed's Avatar
Rewards Points: 13,286
Not a problem in the USA. I Canada lighting must be on 15 amp circuits.
Old 04-21-2012, 10:40 AM   #3
Rewards Points: 13,960
12-2 would be fine, just far more expencive wire. But you need a 15 amp. breaker not a 20.
Old 04-21-2012, 10:43 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Not. As long as is all #12, you can use a 20 amp breaker (in USA).
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Code05 (04-21-2012), HIVOLT (04-21-2012)
Old 04-21-2012, 10:51 AM   #5
Code05's Avatar
Rewards Points: 1,104
Gotta code reference?
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
HIVOLT (04-21-2012)
Old 04-21-2012, 10:58 AM   #6
the Musigician
DangerMouse's Avatar
All the wiring I did here is 12g. Including the 15a lighting circuit. Why would you want lights on a 20a breaker though?
DM
Old 04-21-2012, 10:58 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Personally, for the cost of a bit of wire I'd get #14. You are NOT gonna like having to terminate and splice all that #12 in tiny UC lights.
Save the #12 for some receptacles you'll be adding in the future.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Old 04-21-2012, 11:08 AM   #8
Code05's Avatar
DM
Lights on a 20 amp beaker are fine, but #12 on a 15 amp OCPD is a waste unless done for voltage drop.
Any EC would be out of business if he wasted copper like this, times are way too tight.
HIVOLT (04-21-2012)
Old 04-21-2012, 11:18 AM   #9
the Musigician
Neither reason for me. I simply had rolls of 12g I got at auction for way less than 14g would have cost. Simple math. No UC lights, just overheads, easy install.
DM
Old 04-21-2012, 11:20 AM   #10
Code05's Avatar
DM
Sounds good then.
I would have done the same.
Adding New 20A Circuit - Wiring Check Thadius856 Electrical 14 07-19-2011 11:44 PM
My utility room's wiring, before rewiring WillK Electrical 0 01-07-2011 10:44 PM
Wiring Addition jaymay75 Electrical 4 10-17-2008 10:59 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
