12AWG + 15A Breaker + Bathroom Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2009, 05:54 PM   #1
Rewards Points: 109
12AWG + 15A breaker + bathroom lights
Will only be using it for lights, have dedicated 20A circuits for outlets. Is it ok to use or will I need to up the breaker to 20A?
BimmerRacer is offline   Reply With Quote
Old 08-22-2009, 05:57 PM   #2
Electrical Contractor
kbsparky's Avatar
You can use a 15 Amp breaker on a #12 wire if you want to. No problem-o
-KB
Old 08-22-2009, 09:22 PM   #3
If you already have the breaker go for it
But if you need to buy a breaker the 15a & 20a are about the same price
Old 08-22-2009, 10:38 PM   #4
Question if 15a. breaker safe on #12awg. circuit!
It is safe to use. The other way around (20a. breaker with #14 wire) would be unsafe. Some local codes (Old NYC. pre 2001) would not permit a 20a. breaker on lighting circuits even though the branch circuit wire was #12AWG. (No matter what)Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 08-22-2009, 10:47 PM   #5
Journeyman Wireman
Rewards Points: 150
If there is a 15a breaker in the panel, don't assume that the entire circuit is wired with 12 AWG wire. It's possible that someone has altered the circuit with #14 wire and that 15a breaker is sized correctly.
Jupe Blue is offline   Reply With Quote
Old 08-23-2009, 12:12 AM   #6
Rewards Points: 109
Its an existing circuit I traced back to the panel...nothing else on it.
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
Bathroom(s) Lights formhide Electrical 2 07-02-2008 06:06 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Installing Pot Lights - 12AWG and 14/2 wire ... help! njchan Electrical 4 04-10-2008 06:50 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
