125 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 11:16 PM   #1
125 amp breaker
Hello all, my question is this. Last fall I removed the breaker and all electrical from an old wood electric furnace I had to update to gas. The breaker is 125 amp square D on a 200 amp service square D panel. I installed a 15 amp for the new furnace in a fresh new slot. Now I am left with a large hole in the bottom of the panel where the old one used to go. It took up the bottom 4 slots. What are the options for filling it in?
Kurtiswm is offline   Reply With Quote
Old 06-13-2012, 11:24 PM   #2
Code05's Avatar
Rewards Points: 1,104
http://www.grainger.com/Grainger/SQU...443?Pid=search
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Kurtiswm (06-13-2012)
Old 06-14-2012, 05:33 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
http://www.homedepot.com/webapp/cata...gry=SEARCH+ALL
Coastal South Carolina
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
