#1 |
125/250 receptacle
Got new whirlpool freestanding stove, wiring has black wire, red wire and white(middle)attached 3 prong cord. Problem 125/250 receptacle has 3 prong with white wire in middle, black on left and ground(bare) on right.Everything works in stove, burners heat but not enough. Need help.
#2 |
Licensed electrician
125/250 receptacle
It sounds like your supply is 120 volts. Your electric stove would typically need a 40 or 50 amp circuit at 240 volts.
It sounds like someone might be trying to use the bare as a hot conductor. This would be an extremely dangerous condition. Can you measure voltages from the house wiring?
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| Display Modes | |
| Replacing receptacle with GFCI wiring problem | braden | Electrical | 8 | 04-06-2011 09:32 AM |
| low voltage reading at receptacle | 2 ball cane | Electrical | 5 | 04-06-2011 01:07 AM |
| Switched Receptacle Question | MrBill_DIY | Electrical | 3 | 11-21-2010 11:07 PM |
| Wiring a receptacle for a lift station | hydrogeo99 | Electrical | 4 | 08-18-2010 02:04 AM |
| Receptacle Rating question | KE2KB | Electrical | 5 | 12-18-2008 06:36 PM |
