120vac Temp-switch Running On 12vdc - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 02:13 AM   #1
Question
120vac temp-switch running on 12vdc
I am wanting to use the "Mr. Heater F261210 In-line Thermostat"
(google it if you want to see what i looks like)
It's an In-line Temperature Switch rated for 120vac @ 13A max. I'm wanting to use it to run a 12vdc relay. The relay will draw 140mA. I am wondering if the temp switch will be able to handle 12vdc @ 140mA?
Crossedivide is offline   Reply With Quote
Old 09-22-2012, 06:11 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,902
Yes. Load handling at 12VDC is often about 1/4 to 1/8 of the rating at 120V, so a 13A switch should be fine for at least 2A or so DC, probably much more. 140mA is hardly anything.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Crossedivide (09-22-2012)
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
replacing a dimmer switch with regular switch demus72 Electrical 2 11-10-2011 02:54 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Temp switch / aquastat? Joe F HVAC 3 10-29-2009 12:38 PM
120vac motor running on 60vac airpwr1@graceba.net Electrical 6 01-22-2006 10:15 PM
