-   -   120vac temp-switch running on 12vdc (http://www.diychatroom.com/f18/120vac-temp-switch-running-12vdc-157589/)
Crossedivide 09-22-2012 01:13 AM
I am wanting to use the "Mr. Heater F261210 In-line Thermostat"
(google it if you want to see what i looks like)
It's an In-line Temperature Switch rated for 120vac @ 13A max. I'm wanting to use it to run a 12vdc relay. The relay will draw 140mA. I am wondering if the temp switch will be able to handle 12vdc @ 140mA?
mpoulton 09-22-2012 05:11 AM
Yes. Load handling at 12VDC is often about 1/4 to 1/8 of the rating at 120V, so a 13A switch should be fine for at least 2A or so DC, probably much more. 140mA is hardly anything.
