-   -   120vac motor running on 60vac (http://www.diychatroom.com/f18/120vac-motor-running-60vac-1703/)
airpwr1@graceba.net 01-21-2006 08:46 PM
If i have a 120vac motor, will it work on 60vac but slower and not damage the motor? What electrical part should I use to reduce the volts?
jproffer 01-21-2006 11:58 PM
How are you getting 60VAC and why would you want to convert TO 60VAC if the motor is made for common household 120?
And to answer your actual question: I am inclined to believe that starving it of voltage would burn up the motor.
airpwr1@graceba.net 01-22-2006 08:59 AM
I want To slow the rpm's
jproffer 01-22-2006 02:17 PM
Then you need a variable speed DC motor and an AC/DC inverter. I don't think running at low voltage is going to accomplish what you want to do. And I still think you'll burn the motor up trying.
airpwr1@graceba.net 01-22-2006 04:29 PM
thanks
joed 01-22-2006 07:18 PM
AC motor speed is control by the frequency. Lowering the voltage will only burn up the motor. Change the pulley size or get a different motor.
Teetorbilt 01-22-2006 09:15 PM
You can buy AC motor controllers but they are rather pricey. They are commonly used on industrial machinery motors.
