Is This A 120V Setup? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 08:34 AM   #31
Originally Posted by twilightcall View Post
This is my first house and I am a little scared.
How old is the plumbing? is it copper?
How old is the wiring inside the home? is it knob and tub?
The home has been empty for ten years-the furnace and water heater will more then likely need to be replaced.
What is the condition of the roof?
How is the foundation?
Are the floors level?
Condition of the chimney?
Is the exterior asbestos siding?
The windows are probably older single pane wood windows.
Is the home located in a low ground area resulting in major water in the basement?
All of these are negotiation factors that you can use to get a lower price unless you are already getting the home for below market value.
redline is offline   Reply With Quote
Old 01-07-2008, 08:55 AM   #32
Rewards Points: 150
Roof is ok to main house. Car port roof is very bad. It does have asbestos siding. It has storm windows. Not sure about the plumbing. It has 1 bath and kitchen right next to each other. The laundry room is outside enclosed in front of the car port. It is on very high ground no flooding chances.
twilightcall is offline   Reply With Quote
Old 01-07-2008, 09:01 AM   #33
Rewards Points: 150
Here is a small pic of the triangle thing.
Old 01-07-2008, 09:26 AM   #34
Is this purchase being handled by a real estate agent or private seller?
If the home has asbestos siding then there may be asbestos insulation on the heating system.
It may have floor tile with asbestos.
It may have ceiling tiles with asbestos.
You will need to check the whole house.
The interior paint will more than likely have lead based paint.
Do you have children?
Old 01-07-2008, 09:45 AM   #35
Rewards Points: 150
Not sure if the inside has asbestos. No children. It doesn't have central heat and air but it does have one large vent in the middle of the house that is for the heater. The heating unit is in the crawl space. It is a private seller. I am allowed a termite inspection and home inspection.
The floor in the house is all carpet. I think the walls are drywall.
Old 01-07-2008, 10:45 AM   #36
Originally Posted by redline View Post
I
All these are true, but they have no relation to the fact that there's asbestos siding on the exterior. A 1940s house without asbestos siding is just as likely to have lead paint, asbestos insulation, asbestos flooring, etc as a 1940s house WITH asbestos siding.
I don't think the siding is really something to worry about, especially if it's intact, and you're not planning on removing it. It can be repainted, or covered with new siding, and poses no health risk if it's left in place.
Your inspector should be looking (visually) for asbestos insulation. Flooring is something to consider when you do renovations. The inspector won't be able to tell you if the floor tiles are asbestos.
What are you paying for the inspection? How did you find this inspector? I don't know what the market is like around you, but up here, a $200 inspection is not worth the money. You should look for a reputable company with lots of experience and good references. You should pay closer to $500 for the inspection, IMO. That's cheap insurance and peace of mind, especially when you're a new homebuyer, and when the house is clearly an older one with the likelyhood of some significant maintenance issues.
Good luck with it. Could be a good deal, but make sure you know what you're getting into, and make sure you're paying below market value for a house that's been vacant for 10 years, and has some issues to be dealt with.
Nate
NateHanson is offline   Reply With Quote
Old 01-07-2008, 11:21 AM   #37
Rewards Points: 266
Kind of difficult to see, but that looks like a whole house surge suppressor.
junkcollector is offline   Reply With Quote
Old 01-07-2008, 11:38 AM   #38
Res Ipsa Loquitur
Or an external connection to the original first floor electrical service?
handyman78 is offline   Reply With Quote
Old 01-07-2008, 11:46 AM   #39
Rewards Points: 150
Thanks guys. I appreciate all of the great info.
I choose the home inspection company a family member used for their home purchases. They are more expensive but I heard they are good. They are approx. $400 for a 1000 sq. ft. house. From what I have been told they are very good. Is there another place to look besides the yellow pages for the top home inspectors.
I am doing my best to estimate how much I am going to put into it. I want to keep the house fairly simple but I am not sure how much everything will cost.
I have learned a great deal about electrical just in the past week and reading this board. I had no idea how bad the electrical was on this property. I just didn't know enough about it. So I am sure the same will be true of plumbing etc.
Old 01-07-2008, 12:55 PM   #40
Sounds like you probably have a decent inspector. The worst mistake is to hire an inspector by price, and spend $125 on a totally worthless inspection.
Old 01-07-2008, 06:28 PM   #41
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Exactly.
Speedy Petey is online now   Reply With Quote
Old 01-07-2008, 07:43 PM   #42
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I don't think there is a heck of a lot more to add but I will say this if those tap conductors terminate on that triangle thing dangling there I wouldn't be grabbing hold of it.....
Old 01-07-2008, 07:48 PM   #43
Electrician philosopher
....unless I was fixxin' to gank some free power.
Just kidding.
Andy in ATL is offline   Reply With Quote
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 05:05 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
120v AC thermostat? phantoz HVAC 1 10-29-2007 01:21 PM
gfci problem - 120v between ground and neutral dave0419 Electrical 1 08-18-2007 01:01 AM
220v to 120v blwjrma71 Electrical 4 11-21-2005 07:43 AM
