Old 01-05-2008, 09:16 PM   #1
Is this a 120V setup?
2 wires coming in with a ground wire (metal braided wire). Is this a 120 setup?
twilightcall is offline   Reply With Quote
Old 01-05-2008, 09:19 PM   #2
Here is the picture of the wires coming from the pole.
Old 01-05-2008, 09:24 PM   #3
240V.
Each insulated wire is 120 to ground....240 between them.
The bare wire is the grounded conductor (neutral).
220/221 is offline   Reply With Quote
Old 01-05-2008, 10:08 PM   #4
What size is your main panel box?
redline is offline   Reply With Quote
Old 01-06-2008, 07:05 AM   #5
It is a breaker box. How can I tell the size of the box? Will it say on it? Thanks.
Old 01-06-2008, 07:28 AM   #6
Electrician philosopher
Look at your main breaker. Why are you asking this?
Andy in ATL is offline   Reply With Quote
Old 01-06-2008, 08:03 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
That is an absolutely standard 120/240v service drop.
I'll also ask, what is the actual question?
Old 01-06-2008, 08:55 AM   #8
I just wanted to make sure it was 120/240V service. Here is a pic of it connecting to the house.
Old 01-06-2008, 08:57 AM   #9
This is the pic of the service entrance.
Old 01-06-2008, 09:49 AM   #10
Master General ReEngineer
Bondo's Avatar
Ayuh,.......
As noted above,.... It's a Standard Household Entrance,... 240V.....
Old 01-06-2008, 09:52 AM   #11
Wow. That looks kind of nasty.
I assume the meter is inside the house? POCOs don't like that at all any more.
Old 01-06-2008, 09:59 AM   #12
Looking at the framing I don't think it was built in '04. How old is the house?
Old 01-06-2008, 10:07 AM   #13
what is the extra tap off of the wires (before they go into the wall)
If the meter and main disconnect are at the house then this tap is probably illegal.
Master Electrician
jwhite is offline   Reply With Quote
Old 01-06-2008, 11:19 AM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Yes I would also like to know the meter location. As jwhite said someone has installed split bolt taps on both service drop hots and messenger (neutral). If that is legal I would be very surprised. Could explain exactly where those taps go to and what they land on?
Also the drop looks rather new was this recently done?
Whoever did the drip loop was drunk.
Old 01-06-2008, 11:58 AM   #15
What is a drip loop? The house was built in 45. I didn't make that connection. It was already on the house. The house was vacant for over 10 years.
The meter isn't in the house. It is outside the house under the carport.
So why would they have connected those wires to the incoming wires. They don't go to anything. The taps are connected to some kind of triangle. It is about 1 inch high and wide. The tap wires don't go into the house. Like I said I don't know the history. This is a property we are purchasing.
What is POCO?
240v Air Compressor to 120v help ruacoltsnut General Discussion 10 11-11-2010 05:05 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
120v AC thermostat? phantoz HVAC 1 10-29-2007 01:21 PM
gfci problem - 120v between ground and neutral dave0419 Electrical 1 08-18-2007 01:01 AM
220v to 120v blwjrma71 Electrical 4 11-21-2005 07:43 AM
