120V Receptacle Ground, Up Or Down? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Poll: How do you install your 120v receptacles?
Poll Options
Old 07-17-2014, 07:25 AM   #31
Rewards Points: 4,274
Originally Posted by cj133 View Post
Right now, I'm thinking ground prong up is the safest bet.
Doesn't matter. I break the ground prongs off anyway
Bob Sanders is offline   Reply With Quote
The Following 2 Users Say Thank You to Bob Sanders For This Useful Post:
47_47 (07-17-2014), electures (07-17-2014)
Old 07-17-2014, 07:36 AM   #32
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
What do we do about these?
Coastal South Carolina
Old 07-17-2014, 08:02 AM   #33
cj133's Avatar
Rewards Points: 318
For some reason that made my dad Bob.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-17-2014, 08:03 AM   #34
cj133's Avatar
Rewards Points: 318
IMO those make both ways work because coming out sideways isn't too bad.
Old 07-17-2014, 08:08 AM   #35
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Every code cycle the CMP's receive dozens of proposals regarding this. They refuse to rule on this. It is not governed by the NEC. In my area generally speaking union electricians install ground up. Non union ground down. Additionally you will find ground up in health care facilities. The reason is if an object such as a paper clip falls betwee the plug and receptacle it will deflect without shorting a circuit such as a critical care circuit. Thus not shutting off equipment used for patient care.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
cj133 (07-17-2014)
Old 07-17-2014, 08:22 AM   #36
cj133's Avatar
Rewards Points: 318
A wall plug I've seen a few times that I like a lot is this one.
Not sure where it's from, but it seems like a really good idea though I'm sure it costs more to make so we'll never have such a design. Obviously it's not grounded, but the concept is good.
Old 07-17-2014, 08:38 AM   #37
Rewards Points: 869
was told that if a metal plate came loose, as they do on occassion, and they fall down, they will short the two lugs if something were plugged in. no metal plate - no need.
actually had my son trying to insert a plug in the dark (basement receptacle - metal plate) and drew sparks, because he had the plug oriented normal (ground down) and I had the receptacle ground up.
So the jury is out on which is safer.... in my opinion
TimPa is offline   Reply With Quote
Old 07-17-2014, 10:08 AM   #38
Rewards Points: 1,010
Since being PC is all the craze right now, whether you like the ground prong up or down - we all need to be accepting of alternative wiring styles.
spaceman spif is offline   Reply With Quote
The Following User Says Thank You to spaceman spif For This Useful Post:
jbfan (07-17-2014)
Old 07-17-2014, 10:43 AM   #39
Rewards Points: 3,256
Were you able to figure out why it sparked?
zappa is offline   Reply With Quote
Old 07-17-2014, 10:52 AM   #40
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
European plug at 220 volts.
Old 07-17-2014, 11:11 AM   #41
Oso954's Avatar
Rewards Points: 1,632
It is the euro plug. Rated 2.5 amps at 250V.
Better design is the german schuko. Rated 16 amps at 250V.
It is grounded no matter which way you stick the plug in.
Oso954 is online now   Reply With Quote
Old 07-17-2014, 08:52 PM   #42
Rewards Points: 455
Originally Posted by Jim Port View Post
Given the greater usage of plastic plates this gets less relevant as time passes. I don't think I have seen anything drop across the prongs.
Oh, I've seen it many times and it hasnt hurt anyone but has scared the crap out of them. Mostly where a cord was plugged in and slightly pulled out and various items fell right across the hot/neutral. Necklaces, thin metal objects, etc... We do tons of service calls i've seen a dozen or so over the years so not sure how many times it happens over the nation.
GROUND UP !!!
Cletis is offline   Reply With Quote
The Following User Says Thank You to Cletis For This Useful Post:
cj133 (07-17-2014)
Old 07-18-2014, 08:37 AM   #43
Rewards Points: 869
buest i could guess is that he was kind of probing with the plug for the receptacle (i think we all have done on occassion) got one prong of the plug into the hot, and the other was touching the metal (grounded) faceplate completing the circuit. the load must have been turned on, can't remember what it was, so the current began to flow. i was in the room, heard it, saw it.
Old 07-18-2014, 10:53 AM   #44
Rewards Points: 774
[quote]
I have heard this for 44 years and have yet to see any proff of this happening and if the plate came lose and shorted out that would be YOUR SIGN, to tighten the plate screws.
If he could short it ground up he could have done the reverse.
FIFY
SO in your opinion-The jury is out on which is safer
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
Stubbie (07-18-2014)
Old 07-18-2014, 11:45 PM   #45
dmxtothemax's Avatar
Rewards Points: 5,604
So the outlets will work equally well no matter what there orientation,
But leckies like some uniformity so most will put them ground down,
Probably no great technical reason why,
Just uniformity.
dmxtothemax is offline   Reply With Quote
double ground connections or pigtail in receptacle outlets? JasperST Electrical 15 12-05-2012 03:33 PM
Above ground pool, required receptacle. whatrymes Electrical 22 08-18-2011 07:22 PM
Receptacle ground pin...up or down? jlmran Electrical 19 03-19-2011 08:54 PM
Ground rod per receptacle timc_fla Electrical 17 03-11-2011 07:09 PM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
