120V Receptacle Ground, Up Or Down? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Poll: How do you install your 120v receptacles?
Poll Options
Old 07-16-2014, 06:25 PM   #16
As a rule I like ground down, but no code guidance for which is correct or preferred. I tend to see ground up only in commercial.
mdpeterman is offline   Reply With Quote
Old 07-16-2014, 06:31 PM   #17
joed's Avatar
Rewards Points: 11,596
Normally ground down but it depends on the device being plugged in. last week I installed one for a fridge ground down and one for a portable AC ground up. It was done that way so cords of the devices would hang properly when plugged in. It should be a rule for manufacturers to make their angle plugs all point the same way.
Old 07-16-2014, 07:11 PM   #18
Rewards Points: 774
What ever floats your boat.
Another personal preference, if I put ground up I tape them, ground down no tape
Know A Little is offline   Reply With Quote
The Following 3 Users Say Thank You to Know A Little For This Useful Post:
electures (07-16-2014), rjniles (07-16-2014), stickboy1375 (07-16-2014)
Old 07-16-2014, 07:21 PM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Now thats funny
Coastal South Carolina
Old 07-16-2014, 07:50 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why would someone start a poll on this?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Know A Little (07-16-2014)
Old 07-16-2014, 10:08 PM   #21
cj133's Avatar
Rewards Points: 308
Ok I'll bite even though I find this to be a response only a troll would post as it serves no purpose other than to insult someone.
It's something obviously based on opinions. I wanted to see what everyone's opinion on the subject was.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-16-2014, 10:39 PM   #22
Rewards Points: 3,256
I installed my very first ground up outlet and found that I slept just fine the following night. I think I will switch over for good unless an angle plug dictates otherwise. The only reason for the switch is that I like how the longer ground prong holds the top in and cord weight keeps the other prongs seated better instead of trying to pull them out.
zappa is offline   Reply With Quote
Old 07-16-2014, 10:47 PM   #23
Rewards Points: 1,010
An electrician once told me they recommend ground up because if a plug is not plugged in all the way and something metal falls on the two exposed prongs, it could cause a nasty short, but if the ground plus is on top it would prevent that from happening. Yeah, I know, that's a lot of coincidences to happen...just sharing what he told me!
spaceman spif is offline   Reply With Quote
Old 07-16-2014, 11:16 PM   #24
dmxtothemax's Avatar
Rewards Points: 5,098
I always thought that they put em upside down so
the electrons don't leak out of the bottom hole ?
dmxtothemax is offline   Reply With Quote
Old 07-16-2014, 11:24 PM   #25
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeeeezh !!!
This thread reminds of our U.S. Congress hard at work.
XXX
Old 07-16-2014, 11:37 PM   #26
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Years back I was turned down on inspection because the ground was on top, I got into it with the inspector, he won. I was told electrical and plumbing were just the opposite of each other, plumbing hot on left, cold on right, electrical hot on right, cold (Common) on left, if the ground was up that wouldn't apply. Hey, what do I know, I am an ole nail whooper.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-17-2014, 12:47 AM   #27
Rewards Points: 201
The question is idle enough to invite humor, so here's my attempt.
"I like my outlets the way I like my coffee -- ground up".
Run and find ou is offline   Reply With Quote
The Following User Says Thank You to Run and find ou For This Useful Post:
cj133 (07-17-2014)
Old 07-17-2014, 12:57 AM   #28
JOATMON
ddawg16's Avatar
Rewards Points: 830
This is how I solved the problem in my garage
ddawg16 is online now   Reply With Quote
Old 07-17-2014, 03:45 AM   #29
Rewards Points: 201
"I like my outlets the way I like my tree stumps -- ground down".
The Following 2 Users Say Thank You to Run and find ou For This Useful Post:
electures (07-17-2014), mpoulton (07-17-2014)
Old 07-17-2014, 07:10 AM   #30
cj133's Avatar
Rewards Points: 308
I've considered this my self as well due to right angle plugs apparently coming both ways.
double ground connections or pigtail in receptacle outlets? JasperST Electrical 15 12-05-2012 04:33 PM
Above ground pool, required receptacle. whatrymes Electrical 22 08-18-2011 08:22 PM
Receptacle ground pin...up or down? jlmran Electrical 19 03-19-2011 09:54 PM
Ground rod per receptacle timc_fla Electrical 17 03-11-2011 08:09 PM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
