120V Receptacle Ground, Up Or Down? - Electrical - DIY Chatroom Home Improvement Forum
Poll: How do you install your 120v receptacles?
Poll Options
Old 07-16-2014, 11:08 AM   #1
cj133's Avatar
Rewards Points: 314
120V Receptacle ground, up or down?
I searched and could not find a previous thread so I wanted to see what everyone's thoughts are.
Right now, I'm thinking ground prong up is the safest bet.
This is just a general discussion, commercial, residential, whatever.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-16-2014, 12:01 PM   #2
Rewards Points: 97
I put it down but it doesn't matter to me which way someone else does it.
DBoone is offline   Reply With Quote
Old 07-16-2014, 12:12 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
I put ground down but it no safer in either place.
Old 07-16-2014, 12:16 PM   #4
Rewards Points: 226
Really isn't any justification for it one way or the other that I know of. It's a personal preference. Some people like it to resemble a smiley face, others prefer ground on top. In my mechanical workshop at work (commercial/industrial setting) they are ground up, in my home they are ground down. Just my opinion.
Please wait for the electricians to respond to your post to see if maybe there is a code or mentioned of it in the NEC.
jmon is offline   Reply With Quote
Old 07-16-2014, 12:27 PM   #5
jbfan's Avatar
Rewards Points: 252
jmon, nothing in the code either way.
The Following User Says Thank You to jbfan For This Useful Post:
jmon (07-16-2014)
Old 07-16-2014, 12:32 PM   #6
cj133's Avatar
Rewards Points: 314
I was not able to find any code about it either.
That's why I started the poll, just to see what others think.
I've personally seen where ground prong up would have stopped accidents from happening.
Old 07-16-2014, 01:28 PM   #7
Civil Engineer
Rewards Points: 4,568
The topic of ground up or down has been discussed repeatedly on this forum over the past five years or so, and has prompted a number of rather humorous posts. You may want to search them just for grins. We may already have had a poll on this topic, it has as much relevance is taking a poll on which end of a sheet of plywood should be installed in the up position.
Old 07-16-2014, 01:58 PM   #8
cj133's Avatar
Rewards Points: 314
Except that there is absolutely nothing related to safety or cosmetics in regards to the sheet of plywood's orientation.
I did try searching, nothing came up sadly.
Old 07-16-2014, 02:07 PM   #9
jbfan's Avatar
Rewards Points: 252
Nothing safe or unsafe about the direction of the ground either.
Old 07-16-2014, 02:07 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,902
I'm a big fan of the surprised electrical face. It's the traditional standard. But from a technical perspective ground-up makes more sense because it keeps the hot prong held in by gravity, and keeps foreign objects away from it.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 07-16-2014, 02:10 PM   #11
cj133's Avatar
Rewards Points: 314
See,
Now that's what's up for debate.
However, there is nothing to debate regarding the plywood.
That was my point.
Old 07-16-2014, 02:57 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
All kidding aside, the 2nd image shows a right angle plug (often found on refrigerators and other appliances), plugged into a ground up receptacle.
To me it doesn't hang right and that is why I install them ground down. That is my personal (non-code related) preference.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
cj133 (07-16-2014), dmxtothemax (07-17-2014)
Old 07-16-2014, 04:26 PM   #13
Licensed electrician
Rewards Points: 1,268
Given the greater usage of plastic plates this gets less relevant as time passes. I don't think I have seen anything drop across the prongs.
Old 07-16-2014, 05:01 PM   #14
pbr
Rewards Points: 12
so why does gravity on work in 1 position? and are there any liquid foregn objects?
i could see this subject being stretched out awhile.
pbr
pbr is offline   Reply With Quote
Old 07-16-2014, 05:10 PM   #15
Rewards Points: 30
i like ground up just to be different. but how about a horizontal mounted outlet. neutral up or hot. i like neutral up
bernie
bernie963 is offline   Reply With Quote
The Following 2 Users Say Thank You to bernie963 For This Useful Post:
double ground connections or pigtail in receptacle outlets? JasperST Electrical 15 12-05-2012 04:33 PM
Above ground pool, required receptacle. whatrymes Electrical 22 08-18-2011 08:22 PM
Receptacle ground pin...up or down? jlmran Electrical 19 03-19-2011 09:54 PM
Ground rod per receptacle timc_fla Electrical 17 03-11-2011 08:09 PM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
