120v Only Sub Panel ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 10:22 AM   #1
Rewards Points: 142
120v only sub panel ?
would this be code ?
Fix'n it is offline   Reply With Quote
Old 07-13-2013, 10:47 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Sure, same as a 240V only panel would meet code.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Fix'n it (07-13-2013)
Old 07-13-2013, 10:53 AM   #3
Rewards Points: 142
ok. could i use a 120v only subpanel for a kitchen(gas range) ? 100amp. do they even make 100a 120v breakers ?
perhaps i am over complicating things, or misunderstanding. but it looks to me that a standard sub panel is 240v, true ?
Old 07-13-2013, 11:07 AM   #4
Licensed electrician
Rewards Points: 1,022
A gas stove is fine on a 15 or 20 amp 120 volt circuit.
You will not find a 100 amp single pole breaker.
Most panels are 120/240.
Old 07-13-2013, 11:28 AM   #5
MarginallyQualified
Rewards Points: 2,464
Yes. Perhaps so.
That the various circuits will all be 120V is NOT a reason to
feed the panel with only 120V.
Old 07-13-2013, 12:00 PM   #6
E2 Electrician
Originally Posted by TarheelTerp View Post
Yes. Perhaps so.
I concur, in a residential application, you will probably come to hate this panel in the future...
Old 07-14-2013, 10:07 AM   #7
Rewards Points: 142
thanx fella's.
would 6g stranded wire be good for a 100a subpanel, that will probably never see over 40a ?
panel/breaker brands. are there any to stay away from ?
Old 07-14-2013, 11:21 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Nope...two wire sizes too small...3 AWG
The Following User Says Thank You to k_buz For This Useful Post:
Fix'n it (07-14-2013)
Old 07-14-2013, 11:23 AM   #9
Rewards Points: 142
would these wires be ok in 1/2" conduit ?
Old 07-14-2013, 11:24 AM   #10
k_buz's Avatar
Not even close...minimum 1" EMT
Old 07-14-2013, 11:34 AM   #11
Rewards Points: 142
darn, i have a bunch of 1/2". oh well, it is what it is.
Old 07-14-2013, 11:40 AM   #12
Rewards Points: 142
oh. i do not have a 1" bender. what are my other options ? please say i have other options !
there would only be 2 90's.
Old 07-14-2013, 11:50 AM   #13
Engineer
Rewards Points: 161
Buy pre-fab bends
diystephen is offline   Reply With Quote
The Following 2 Users Say Thank You to diystephen For This Useful Post:
Fix'n it (07-14-2013), stickboy1375 (07-14-2013)
Old 07-14-2013, 09:24 PM   #14
Rewards Points: 142
i didn't know they had those. i will look for them. do the box stores have em ?
i was thinking those elbows that have the caps on em.
anyone care to comment on the box/breaker question ? i don't want to get a pos or oddball.
Old 07-14-2013, 10:18 PM   #15
MarginallyQualified
Whatever brand/type you use (or have) for the main panel.
No duplication & maximum re-usability of bits.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
