120v Gas Range Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 04:48 PM   #1
120v gas range wiring question
I am changing my old electric range to a new gas range. Is it permissible to use the heavy existing 220v wiring to the old electric range for powering a new gas range that requires 120v?
My intent is to unhook the existing wire from its 50 amp breaker and run it to a 20 amp breaker, using the red as the ground (and clearly identifying it as such).
I also intend, of course, to install a 20 amp receptacle in place of the old 220v range receptacle.
If this is acceptable it will greatly simplify the wiring requirement for the new range and still leave the old wiring available for an all electric range in the future.
Redfishjoe is offline   Reply With Quote
Old 05-11-2011, 04:57 PM   #2
Electrician
Rewards Points: 792
Nope can't do that. If you have a bare ground you could do as you plan. Red cannot be reindentified to green.
darren is offline   Reply With Quote
Old 05-11-2011, 04:59 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
What color and how many wires are in the existing cable? It is not code compliant to remark a red wire as ground (and I assume you mean neutral)
Coastal South Carolina
Old 05-11-2011, 05:10 PM   #4
I ask the impossible!
Rewards Points: 660
what they said
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-11-2011, 07:50 PM   #5
Thanks for the info guys
Upon re-examining the existing wire I've found that it is a 4 wire cable - red, black, white, and a bare ground. I believe I'll be able to use this for my 20 amp 120v circuit now.
Will save me a lot of headache!
Old 05-11-2011, 09:37 PM   #6
Electrician
Rewards Points: 792
Change the breaker to a 20A and pigtail a #12 on the wire and you will be good to go.
Question on surface mounted wiring, plus ... NancyNGA Electrical 0 03-17-2011 01:11 PM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
Electric/Gas Range Question txrun Electrical 3 12-23-2009 08:25 PM
Basement wiring question kupalino Electrical 8 11-14-2009 09:25 AM
Range hood wiring question, help!! nyc_apt_dweller Electrical 4 03-05-2009 08:34 PM
