-   -   120v to 12v converter? (http://www.diychatroom.com/f18/120v-12v-converter-13518/)
Hollow 11-18-2007 04:17 AM
Im trying to install a bilge blower from a boat in my aquarium. Im not sure how to wire it since it was made for a boat. Im assuming I need some kind of converter. I have no electrical experience so ill post a link with the product and specs. http://cgi.ebay.com/ebaymotors/ws/eB....cWAT.m240.lVI
Any help will be appreciated. Thanks.
elkangorito 11-18-2007 07:51 AM
More information needed.
Do you require 12 volts AC or DC? How big is this "blower"? Please supply all details like;
1] voltage requirements.
2] current requirements.
3] power (Watts).
4] AC or DC.
5] approximate physical size of the blower.
Hollow 11-18-2007 07:54 AM
Housing is molded tough corrosion-proof ABS plastic. Rugged built-in mounting brackets for easy installation. Molded tabs on all hose flanges provide positive hose connections. Ignition protected
Spark proof
4" (10.16cm) Intake
4" (10.16cm) Exhaust with remote bracket
5-3/4" (14.61cm) Length
4-3/4" (12.07cm) Mounted height
CFM 240 Air movement.
Ignition protected 12V DC, 4.5 Amps
Use 5 Amp fuse.
Blower meets or exceeds these standards: ABYCH H-2
NMMA Certified
USCG 33 CFR Sections 183.410 and 183.425
ISO 9097
UL Listed
UL 1128 Standard Marine blowers.
Hollow 11-18-2007 07:55 AM
thats all I know
elkangorito 11-18-2007 08:03 AM
From the information that you have provided, you need a commercially available 120 volts AC (single phase) to 12 volts DC power supply, rated at a minimum 60VA (60 Watts). My ideal choice would be to get an 80VA power supply but they may not be available. If all else fails, get a 100VA power supply.
jwhite 11-18-2007 08:13 AM
You will need a power supply similar to the ones shown on this page
http://www.radioshack.com/search/ind...wCatId=2032056
13.8 is the often the actual operating voltage of a 12 volt system while the batteries are being charged by the alternator.
If you use one like this you will also need an in line fuse. The tech page recommends 5 amp fuse.
I did not look, but you may find something from a security company. Those systems often use 12 volt, but I am not sure that you will get 5 amps. Often those systems only use 500 or so ma.
You may get good results by stopping by a car audio store. It is very common for people to buy power supplies to either bench test equipment, or use their car stereo in the garage.
Speedy Petey 11-18-2007 09:42 AM
I would get a 10-15A PS at the smallest. You can get these all day on Ebay. I would not get the 5A supply, this is right at the load of the fan and you want some cushion.
Do you really need a 4" ducted fan for a fish tank ?????
240CFM is a LOT of air!
arichard21 11-18-2007 09:50 AM
the question also should be why do you need a bildge BLOWER for a fish tank... do you need to ventilate the tank?
are you sure you dont need a bildge PUMP? they are 2 totally different things. a blower will evacuate fumes from the engine compartment of an ib/ob while a bildge PUMP pumps water from the bildge of the boat. it would make more sense that if it is for a fish tank, then a pump would be what is needed..
but i could be wrong too.
joed 11-18-2007 09:52 AM
Use an old PC power supply. The yellow and black are the 12 volt power lines.
