120 Volt Only Load Center? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 03:05 PM   #1
120 volt only load center?
I know I have seen them, but cannot find any. I am running 3 20 amp computer circuits and want to keep them on one phase, a 120 volt load center would be ideal. Anybody seen any (preferably QO).
rgsgww is offline   Reply With Quote
Old 01-28-2009, 03:41 PM   #2
Licensed Pro
If you mean one leg of your panel, just alternate breakers.
Old 01-28-2009, 04:16 PM   #3
I will sell you a 120V only panel. They're a little expensive. Just send me $100 and I'll send it to you and give you the instructions on how to hook it up. Just ignore one screw terminal and you'll have to skip breakers. Make check payable to ...
jerryh3 is offline   Reply With Quote
Old 01-28-2009, 04:25 PM   #4
I don't think it is illegal to install a jumper on the main lugs.
220/221 is offline   Reply With Quote
Old 01-28-2009, 05:05 PM   #5
A jumper? Makes sense. I'll have to see if its ok.
Old 01-28-2009, 05:08 PM   #6
" Euro " electrician
frenchelectrican's Avatar
It can be done by using the jumper IMO just make sure you mark the cover panel stated 120 volts only ditto inside as well to make sure someone is paying attetion to this one.
Merci,Marc
Old 01-28-2009, 05:14 PM   #7
Merci,Marc
What would you call this jumper? Any name? I have searched and can't find real results.
Old 01-28-2009, 05:29 PM   #8
Rewards Points: 2,350
I would call the jumper a piece of wire. You could strip the hot a few inches down from the end and loop it through the first lug and on to the second, that way there is only one wire per lug.
Old 01-28-2009, 05:33 PM   #9
Normally in my tougne { langaune } it called " Fil de sauteur " it mean jumper wire { translated from French}
or can use what some of the electricians called " jumper bar " that work as well.
I will wait and see what other have better suggest here.
Merci,Marc
Old 01-28-2009, 05:37 PM   #10
Maintenant qu'est la bonne faon de le faire pour le jeu en haut et aussi c'est plus sr cette voie.
{Now that is good way to do this for the set up and also it is safer this way.}
Merci,Marc
Old 01-28-2009, 06:14 PM   #11
Idiot Emeritus
Rewards Points: 1,492
I design and build industrial control panels once in a while, it's very common to use a single-phase panel and jumper the two hots together, then feed it with a 30 - 60 amp 120 volt circuit.
The only possible code problem I can see is you'd have more than one wire under a lug that might not be listed for more than one wire. (110.14A) I've never had an inspector turn one down yet. The solution would be to wirenut the feed with two pigtails, and land each one under a lug. Inphases idea would likely be OK though.
Rob
P.S. One possibility is a Square D QO35FM30TTF/S. This is a 2 wire panel designed for a small travel trailer. It's designed for a QO breaker to be installed as a main, I don't know if it has a main lug or not. It has 3 spaces + the main.
micromind is offline   Reply With Quote
Old 01-28-2009, 06:48 PM   #12
It's a "jumping from one bus to the other bus" jumper.
Old 01-28-2009, 07:07 PM   #13
Thank you all very much You have saved me alot of time and trouble!
Old 01-28-2009, 07:18 PM   #14
Electrician
okay, now the stupid question, what purpose does it serve to keep them on one leg of a single phase service? I am completely confused.... ( is this a single phase service? )
chris75 is offline   Reply With Quote
Old 01-28-2009, 07:22 PM   #15
Its just because computer equipment will be on the circuits, and that they will be connected together. I dont want the voltage difference. Computer PSUs and mwbc don't mix very well.
I am thinking about a load center because I'm getting tight on space.
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 04:14 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
Load Center dwayne Electrical 4 07-09-2006 01:02 PM
100A load center run Littlefatdog Electrical 12 06-15-2006 02:31 AM
