120 Volt Off 240 Volt Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 02:06 PM   #1
Rewards Points: 113
120 volt off 240 volt circuit
Forgive me for asking what I'm sure has been asked many times---I didn't find it in the search.
I have a 240 volt circuit with a double 20 amp breaker and 12/3 with ground wire. I assume that either black or red wire with an excess of 20 amps will trip breaker ( both throws are tied together). The circuit is dedicated to an air compressor. In the 240 box, I want to pigtail off the black, white and ground wires for a 120 outlet. This sounds too easy so it must not be possible or against code. In either case, I'll access a 120 outlet----a much harder task because of location.
Against code or not possible?
Captflx is offline   Reply With Quote
Old 03-09-2009, 02:29 PM   #2
Rewards Points: 2,350
What does the circuit feed now? As long as the circuit has a neutral, and the breaker is a double pole and the correct amperage, then it is legal.
Old 03-09-2009, 03:22 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Not possible by your description you do not have the neutral as inphase was asking. You cannot use ground as your neutral.
12/3 with ground would imply you have a neutral but you do not mention a white wire??
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-09-2009, 03:37 PM   #4
Read it again. There is a red and black at the breaker(The way it sounds). Black and white(and hopefully red) at the 240 outlet.
jerryh3 is offline   Reply With Quote
Old 03-09-2009, 03:43 PM   #5
joed's Avatar
Rewards Points: 11,992
That will work.
Old 03-09-2009, 04:04 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Yep, I should have been more careful in reading. He could certainly use this for a line to neutral load.
Stubbie
Old 03-09-2009, 08:53 PM   #7
Rewards Points: 113
I was refering to the white wire as neutral. I have a red, black, white and bare ground.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
