120 Or 240 Volt, Difference In Meter Reading? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 11:46 AM   #1
Rewards Points: 502
120 or 240 volt, difference in meter reading?
I am installing a new pool pump soon, and the information I was seeing before ordering said it could be hooked up to 120 or 240 volts.
This is a pretty beefy motor, so it is likely that it would be the largest 120 volt aplience when running. whould the resulting imbalace in electrical legs (half of the 240 volt circut) cause a higher watt reading on the electric meter?
basically what I am asking is if a 120volt 20 amp draw would be read by the utility meter the same as a 240 volt 10 amp draw?
I am leaning towards hooking it up in 240 just for reduced loss due to resistance in the wireing.
could I possibly hook it up to the 240 volt terminals and stick in a multi pole switch to run it in 240 or 120 volts to give me the option of a half power setting? They do make 2 speed versions of this pump, but I couldn't justify the extra couple of hundred they charge for them. Can I get it free?
forresth is offline   Reply With Quote
Old 06-01-2010, 11:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 268
The meter will read it the same way.
You can either connect it to 120volts, or 240 volts, but not both.
You can not get two speeds from a single speed motor.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
forresth (06-01-2010)
Old 06-01-2010, 01:23 PM   #3
joed's Avatar
Rewards Points: 12,036
Watts is watts. It doesn't matter what the voltage is. 240 is a bit more efficient since there will be less voltage drop do to lower current.
Old 06-01-2010, 03:10 PM   #4
Rewards Points: 502
Thats what I figured, but I wasn't shure there wasn't something like a PCF at play with the meter.
Old 06-01-2010, 04:45 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the 240 also allows for lower rating of circuit and due to that, often a smaller size of wire. Smaller wire generally costs less. It's not as applicable in a resi situation but does sometimes come into play.
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 02:12 PM
SE Conduit & Meter placement acerunner Electrical 11 03-18-2010 09:46 AM
New clamp meter question Chevyman30571 Electrical 18 02-22-2010 12:35 AM
Meter Shutoff Ultrarunner2017 Plumbing 14 03-18-2009 08:29 AM
Different styles of 220 volt recepticles? MrLinux Electrical 8 01-24-2008 07:47 PM
