Old 01-20-2009, 05:32 PM   #1
120/240 hookup for Jenn-Air cooktop
I am replacing an older Jenn-Air cooktop (mod # C-201) with a new Jenn-Air cooktop (mod # JED8430). My problem/concern is that the 120/240 circuit feeding the cooktop is fed via Greenfied conduit housing 4 wires [ (2) black, (1) white (1) bare copper ]. The new cooktop attached junction box has 4 wires [ (1) black, (1) red, (1) white and (1) green. It seems intuitive enough to me that white connects to white as a neutral and that green connects to bare copper as an appliance ground. BTW, white and bare copper are bonded together at the service panel, i.e. continuity is read between the 2 wires as well as at the neutral and ground bus bars. No problem so far. My concern is the proper connection of the two "hot" black wires which normally would be (1) black and (1) red. Since the two hot wires are phase reversed and together provide the 240v energy I'm concerned that if they are incorrectly connected backwards some form of polarity problem may exist which could cause damage to the unit.
A related issue is that the exhaust fan motor (120v) is fed from Hot wire L1 and the neutral wire (white). I don't know which of the (2) blacks is L1 and which is L2. At the time the fan is working and drawing current from L1 some imbalance would exist between L1 and L2 which might imply that it is critical to connect the two correctly. It may well be that if I wire L1 and L2 backwards the fan may not work or worse, some damage to the unit might occur.
I would be most grateful for your advice on this matter.
jroho is offline   Reply With Quote
Old 01-20-2009, 05:39 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
It doesn't matter which black wire of the supply you connect to the red and black of the cooktop. There isn't a phase reversal only a 180 degree offset of the single phase source between the two. Both wires are 120 volts to neutral, the exhaust fan could care less which hot L1 or L2 it uses.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-20-2009, 05:45 PM   #3
Thanks, Stubbie. Relieves my worries.
BTW, good luck to the UAW during this economic crisis. We need US cars and US jobs!
Old 01-20-2009, 06:49 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
This is pretty much what you have going on with your cooktop. I didn't show the safety ground or the cooktop junction box (you will have to use your imagination...) You can see that it will not matter which supply wire the two hots connect to nor which one supplies the 120 volt loads.
120/240 hookup for Jenn-Air cooktop-cooktop-circuit.jpg
Stubbie
Old 01-20-2009, 07:06 PM   #5
Thanks, Stubbie. That makes it much clearer. As I always say "A day without learning is like no day at all!" My day is now complete. Thanks
Gas Cooktop Gap with Counter Mickey53 Appliances 8 07-03-2011 04:27 PM
Wiring a Jen-air cooktop gunnydon Electrical 4 12-19-2008 12:33 AM
Kitchen Remodel - Gap around CookTop Mickey53 Remodeling 4 11-08-2008 10:15 PM
need help with a new cooktop m_shel Electrical 9 02-08-2008 10:56 AM
