#12 Wire, Stranded Or Solid? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 10:53 PM   #1
#12 wire, stranded or solid?
#12 wire, stranded or solid? Whats the reason to use one over the other?
I need to run some wiring in my shop and would like to know what you the difference is.
Serrano7503 is offline   Reply With Quote
Old 11-07-2011, 10:54 PM   #2
Electrician
Rewards Points: 760
Nothing, I find #12 solid easier to work with once you start putting it on plugs and switches.
darren is offline   Reply With Quote
Old 11-07-2011, 11:17 PM   #3
Solid will be slightly smaller in diameter. Stranded is slightly larger but more flexible. I agree that solid is easier to work with for most tasks.
brgmgb is offline   Reply With Quote
Old 11-07-2011, 11:18 PM   #4
Thats what i was looking for,
Thx!
Old 11-07-2011, 11:19 PM   #5
Stranded wire works better if you have sharp bends or if subject to flexing.
hayewe farm is offline   Reply With Quote
Old 11-08-2011, 06:38 AM   #6
Limited Experience
I would tend to think that solid is not allowed if flexing is a possibility.
raleighthings is offline   Reply With Quote
Old 11-08-2011, 11:27 AM   #7
Use stranded for cables which move. Notice that appliance cords use stranded wires.
If you take a [solid wire] coat hanger and bend it back and forth many times, it will break.
Then much easier to secure a solid wire around a screw like the screw on the side of an outlet or switch.
Billy_Bob is offline   Reply With Quote
Old 11-08-2011, 12:28 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 816
There ya go.....
Performance wise....both are about the same....but the mechanical aspects are what dictates what you use.
Try to attach a stranded wire to the screw of a typical outlet....better yet, don't try.....not safe unless you use a crimp on connector.
Both types will wire nut up just fine....If my run is using stranded....then when I get to a recpt box, I will make a pig tail using solid wire to connect to the recept.
And if you ever try to pull solid through conduit.....then you will understand real fast why most people do not pull solid through conduit.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
Stranded wire in breaker? gma2rjc Electrical 3 09-25-2010 01:00 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
connecting straight wire to stranded Cossack Electrical 5 07-30-2010 02:52 PM
