12 Volt Winch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 05:16 PM   #1
12 Volt Winch
I have hooked up a 12 volt winch to my 4x4 atv, for my plow, and want to install a n.c. limit switch in the "up" circuit, to prevent my plow from smacking into under belly of atv. I know it will work, and kill power when limit switch is opened, but is there something in limit switch itself, to allow constant voltage to "down" side of circuit, so that pressing down button will allow plow to drop. Hope this doesn't sound like a lot of rambling!
903ASP is offline   Reply With Quote
Old 07-10-2008, 05:22 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If your feed is paralled into your push buttons, the limit switch should just be breaking the "up" lead and not affect the down.
wirenut1110 is offline   Reply With Quote
Old 07-10-2008, 05:36 PM   #3
Only fair when it comes to electrical "wirenut". I downloaded an elec. drawing of my up/down switch to my computer, is there anyway i can get the image to you, so you could check it out?
Old 07-10-2008, 06:20 PM   #4
Rewards Points: 510
I sent you a pm with my email address
Old 07-10-2008, 06:37 PM   #5
Ok wirenut, took me some searching, but i found info, and emailed schematic. Thanks for your help
Old 07-10-2008, 07:19 PM   #6
Just a note to all: Wirenut110 straightened me out, and solved my limit switch/winch circuit problem, and i'd like you all to know how much i appreciate his help. Keep it up my friend, you're an asset to this site
120 volt house service junkcollector Electrical 10 12-15-2011 04:51 PM
Different styles of 220 volt recepticles? MrLinux Electrical 8 01-24-2008 06:47 PM
Dewalt big 18 volt set timmy Tools 4 08-14-2007 10:32 PM
Ryobi 9.6 Volt Drill/screwgun bobo Tools 1 11-26-2006 07:34 AM
Volt coming into house whitepa254 Electrical 9 02-20-2006 04:55 AM
