12 Volt Photocells - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 03:14 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
12 volt photocells
Does anyone know of a source for an inexpensive 12v photocell
i want to set up some of the 12v outside lights so they come on automatically at night, and won't come on during day, but can't find anything in a stand alone photocell for under $80, which is 10x more than the ones for 120v
it's hard to believe they actually cost this much, since any solar light you buy for $10 -$50 usually has this built in
Mr Chips is offline   Reply With Quote
Old 08-10-2009, 03:32 PM   #2
300zx's Avatar
Post
http://www.nextag.com/12-volt-60-wat...er/search-html http://www.homegardenandpatio.com/ca...s_lights_porch
300zx is offline   Reply With Quote
Old 08-10-2009, 03:38 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
that looks like it plugs into 120v and steps down to 12v.
i am doing a solar system and don't want to use inverter. i want something that would wire straight into 12v
Old 08-10-2009, 04:48 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,856
Most of the manufacturers of small solar charging controllers have models that provide automatic light switching, too. For example, the Morningstar charge controllers are available with a lighting control option. These units are not dirt cheap, but not much more expensive than a plain charge controller, which you need anyways. Just search for "solar light controller" and you'll find loads of options.
mpoulton is online now   Reply With Quote
Old 08-10-2009, 04:58 PM   #5
300zx's Avatar
Post
You could try this one.I would email him and make sure its not 12 volt http://cgi.ebay.com/Low-Voltage-Nigh...QQcmdZViewItem
Old 08-10-2009, 04:59 PM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
12 volt photocell
Will this work for ya?
wirenut1110 is offline   Reply With Quote
Old 08-10-2009, 05:45 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by wirenut1110 View Post
12 volt photocell
Yes, that's more like it. i was hoping to find something even cheaper, but that is a lot better than what i have seen before
Old 08-10-2009, 06:14 PM   #8
It's the $37
or
$5 or $10 in parts including a CdS photocell and you assemble/test/debug from a design that's sure to work. I think the circuit comes with the Radio Shack datasheet included with their photocell. With this option you can hide most of the electronics (it's cosmetically pleasing).
The tradeoff that cannot be gotten around with either unit is that if you set the sensitivity so that it comes on later (darker) it will be sensitive to any passing light source.
And of course the controlled lights cannot be anywhere near the photocell or you will have an oscillating system.
Old 01-21-2010, 04:24 AM   #9
The answer to your question
I have found a company in the UK that make 12v DC Photocells and ship all over the world for just a few bucks. The unit price at the moment is about USD25.00. www.acetek.co.uk .
answers is offline   Reply With Quote
Old 01-21-2010, 05:35 PM   #10
Rewards Points: 30
Try looking for those "keep your car battery from dying" photocells. I bet Harbor Freight has something that could work for you for less than $10.
<My mistake. I thought you meant photovoltaic cells, aka "solar panels.">
Last edited by Wino; 01-21-2010 at 05:40 PM. Reason: lack of reading comprehension on my part
Wino is offline   Reply With Quote
Old 04-16-2010, 11:51 PM   #11
How about this?
I came across this forum while gooogling this particular topic. I joined up just so I could show you the best thing I've found...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110520652851
It's a light controlled 12v switch sold out of the UK for about $21 USD.
Of course, it's quite likely that as you read this thread, the eBay item will have expired. So here's how I found it: I tried a number of combinations of search terms, but the golden ticket was "12vdc automatic switch".
What I want to do is automate the headlights in my car. But I can't tell you (yet) whether this will help you or me.
Let me know if it works out, if you decide to try it.
zer024 is offline   Reply With Quote
Old 10-25-2010, 01:05 PM   #12
Wouldn't it be possible to use one of the photocells out of a Harbor Freight yard light? I see they have three solar powered "Tiki lights" for $7. Each has a photocell in it. Voltage might be wrong, but that should be fixable with a resistor in the circuit.
Goomer is offline   Reply With Quote
Old 03-24-2012, 11:22 PM   #13
Photoresistor
It sounds like we are at the same stage of solar experimentation. Try a search for a photoresistor, the component that you may be looking for.
james1586 is offline   Reply With Quote
Old 03-25-2012, 12:57 AM   #14
12 volt photocell no longer needed
The solution to the problem was simple. I have an automatic chickenhouse door opener/closer that runs off 110 power. The system is 120 volt, and when there is a power loss, it causes all sorts of problems, including leaving the door open so the raccoons can get to the chickens. I was going to build an entirely new 12 volt system when I realized all I really wanted was a battery backup to the system. I took a Harbor Freight "12 Volt Jump Starter and Power Supply", plugged it into the existing 110 outlet to keep it charged. Off to the side of it I plugged in a Harbor Freight 80 Watt Continuous Power Inverter, then plugged the opener system (with 110 volt photocell) into that. So, the battery is continuously charged and the door operates off the power from the invertor. If power is lost, the door will operate for days from the power available from the battery. So, the need/search for the 12 volt photocell ended. Been working fine for over a year and through a couple power losses. Not the most efficient thing going, energy wise, but the power drawn is pretty minimal.
Old 03-25-2012, 01:30 AM   #15
Great!
I'm happy that you found a solution. It sounds rather complex, but then I realized that each of the components could be used for other purposes if needed. It certainly fills the need you had. Good thinking.
I recently got into solar and electronics as a hobby and have just started my learning and development stage. I have just built 3 solar panels from scratch. They each should deliver 60 watts and I am exploring uses for them. I was able to acquire 2 200aH batteries for my experimentation, so I think that I am close to getting it all going. I am in the process of building my own charge controllers, but am hitting a snag with figuring out what to do with excess power.
Hate to write so much as a newb, but am hoping that I can attract some similar interest to help me along the way.
220 volt circuit GFCI Captflx Electrical 16 09-29-2011 07:53 AM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 11:49 AM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 07:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Different styles of 220 volt recepticles? MrLinux Electrical 8 01-24-2008 07:47 PM
