12 Volt Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 06:17 PM   #1
12 volt lighting
we installed 12 volt medium base 15 watt fluorescent bulbs in our camp and they will burn only mins before they blow...any suggestions
flhxfred is offline   Reply With Quote
Old 09-03-2012, 06:44 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,362
How stable is the 12v supply ?
If its too high !
if it has spikes and surges on it !
what else is running off the 12v system ?
Or they are just crap quality lamps !
dmxtothemax is offline   Reply With Quote
Old 09-03-2012, 07:10 PM   #3
Rewards Points: 13,740
Did you install the transformer to step down the voltage?
k_buz (09-03-2012)
Old 09-03-2012, 11:27 PM   #4
awd
I had the same problem. I used the garden Malibu light Transformer (44W capacity) and connect a 13W 12V(RV lights), CFL bulb to it, I had other 4W path accent lights but the total W is under 40W....
The CFL bulbs (in the Post lamp) lasted 2 nights only. It stormed the seconds night and it blew the CFL bulbs but not the other 4W "Malibu" lights.
I Have not buy another (Malibu) lamp post with 15W "malibu" bulbs (but they are not LEd nor CFL) and settle for a not so bright post lamp. No blown bulbs for 1 yr now...
Is the malibu transformer not suitable for these 12V (RV) CFL bulbs? Will this Malibu transformer wokr well woth LED bulb? (If I can find one that is bright enough That don;t cost an arm and leg!+
awd is offline   Reply With Quote
Old 09-03-2012, 11:31 PM   #5
Is the maliboo tranny electronic or iron cored ?
Old 09-04-2012, 12:02 AM   #6
awd
don;t know exactly... It comes with the cheap Starter Kit (with 10x4W plastic landscape accent lights)..,. It doesn;t have digital read out. only photo sensor to turn it on/off.
hope this help?
Old 09-04-2012, 12:33 AM   #7
Oso954's Avatar
Rewards Points: 1,124
Your CFL's are most likely 12V DC.
Your Malibu transformer is 12V AC.
Oso954 is online now   Reply With Quote
Old 09-04-2012, 06:27 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
This is a case where I think 12Vdc LED lighting is a better way to go.
Old 09-04-2012, 07:02 AM   #9
If its too high !
there is nothing else running off the 12 volt battery, we payed $7.00 fo for the bulbs not that nessary means they arent crap, is it safe to assume that a 12 volt battery is 12 volt or could it be higher??
Old 09-04-2012, 08:19 AM   #10
we are using a 12 volt battery
Old 09-04-2012, 12:48 PM   #11
Oso954's Avatar
Are the lamps reverse polarity protected ?
How many lamps did you install over what size and length of wire ?
Old 09-04-2012, 04:49 PM   #12
umm not sure on the reverse polarity.....5 lamps in 5 rooms 12 guage wire...no more then a 20 foot run I believe
Old 09-04-2012, 06:37 PM   #13
Do you run the lights at the same time as when you are charging the battery ?
Have you measured the voltage with all the lights on ?
If its a battery, too high a voltage is unlikely.
But low voltage could contribute to short life.
I would guess at this stage its just poor quality lamps !
12 volt landscape lighting help BARCAT Electrical 4 08-24-2012 08:52 PM
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
12 volt lighting nealwest Electrical 3 08-05-2011 08:00 AM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
12 volt kitchen cabinet lighting wire gauge? Help! :/ Lupinglade Electrical 16 09-25-2009 11:55 AM
