12 Volt 3 Way Sw With Off Position - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 11:54 AM   #1
12 volt 3 way sw with off position
Iím looking for a 12 volt 3 way rocker arm switch with an off position. The purpose of the switch is to be able to power an inside trailer light from a truck when it is connected and from a battery when it is not. Without having both power sources accidently connected at the same time.
George Wotton is offline   Reply With Quote
Old 09-04-2012, 12:05 PM   #2
Rewards Points: 756
You want a SPDT switch.
Radio Shack or the big box stores should carry them. If not, try someplace like West Marine.
AandPDan is online now   Reply With Quote
Old 09-04-2012, 12:10 PM   #3
Search google.com for SPTT switch (Single Pole Triple Throw)...
Here is one of many...
http://octopart.com/2ge51-73-carling-6129796
Billy_Bob is offline   Reply With Quote
Old 09-04-2012, 04:59 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,928
He only needs double throw, not triple. A SPDT switch with center-off will work fine.
mpoulton is offline   Reply With Quote
Old 09-04-2012, 05:37 PM   #5
joed's Avatar
Rewards Points: 12,464
He wants a center off position not a simple double throw.
Old 09-04-2012, 06:48 PM   #6
Rewards Points: 756
You can have 3 positions with SPDT.
Here:
Old 09-04-2012, 07:02 PM   #7
Missouri Bound's Avatar
Ahem....he wants a "ROCKER" switch, not a toggle switch.
Do you want it your way or the right way?
Old 09-04-2012, 07:12 PM   #8
Rewards Points: 756
Fixed.
I guess I'm the search engine. Just call me Google next time.
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase arbailey Electrical 5 05-24-2012 08:43 PM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
