#12 Internal Wiring In A GE 4500w Water Heater - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-15-2011, 10:29 PM   #16
I didn't say that current doesn't always affects insulation temperature rating I said temp doesn't affect conductor current caring capacity. If you have two units both drawing the exact amount of current, one being a hot oven and the other a refrigerated unit that is at -30F the allowable gage of the wire would be the same but the insulation rating would be required to be different. If a lower rated insulation is used in the oven the current allowed would be dropped because of the amount of heat produced by the amperage which is a de-rating do to a faulty choice not the current carrying capacity of the conductor.
hayewe farm is offline   Reply With Quote
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Timer Wiring? brentjroberts Electrical 2 11-05-2008 02:41 PM
