12 Gauge (20A) Wiring Do I Need 20A Recetpicles Or Is A 15A Duplex Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2008, 07:59 PM   #1
Rewards Points: 150
12 gauge (20A) wiring do I need 20A recetpicles or is a 15A duplex ok?
I have 12 gauge wire (20A circuits) in my dining room and living room. Do I need 20A recepticles or is a 15A duplex ok? If it gets load over 15A will the duplex fail first vs. the breaker? Thanks.
twilightcall is offline   Reply With Quote
Old 06-30-2008, 08:02 PM   #2
Licensed Pro
As long as you have more than one receptacle, and a duplex counts as two, then you may use the 15A receptacles.
Old 06-30-2008, 08:54 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Unless of course you are in Canada.
And NO, the 15A duplex will NOT "fail".
Old 07-01-2008, 09:53 PM   #4
Idiot Emeritus
Rewards Points: 1,492
It's completely to connect 15 amp receptacles to a 20 amp circuit, it's also a very common practice.
I'd bet your kitchen and laundry receptacles are 15 amp, and they're almost certainly on 20 amp breakers.
The only time you can't have a 15 amp receptacle on a 20 amp circuit is if it's a single (not a duplex) receptacle. One or more duplexes are fine.
The 15 amp rating has to do mainly with pin configuration, and not current carrying ability. If you removed the face of a 15 and a 20 amp receptacle from the same manufacturer, you'd find the base (where the actual electrical contacts are) would be identical.
You can't burn up a 15 amp receptacle just by putting it on a 20 amp circuit.
Rob
micromind is offline   Reply With Quote
Old 07-02-2008, 05:37 AM   #5
Rewards Points: 150
Thanks guys. I just wanted to make sure. I have all of my new wires roughed in and am at the point of installing new recepticles. I appreciate all of the help. When would you use a 20A duplex?
Old 07-02-2008, 07:01 PM   #6
Idiot Emeritus
20 amp receptacles are very common in commercial and industrial applications. In 18 years of doing mostly comm'l/industrial, I've seen maybe 2 or 3 20 amp 125 volt cord plugs, and all these were on equipment that required a dedicated circuit, and used a single receptacle.
Rob
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Two Family Duplex - Garage Wiring Question Moonlight24 Electrical 2 06-22-2008 10:31 AM
Ceiling fan wiring beezlebub03 Electrical 8 05-05-2008 06:34 AM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 12:55 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
