Old 08-07-2012, 04:19 PM   #1
12 ga duplex receptacle
What can I use or not use in replacing old push-in back-stab receptacles on 12 ga wiring with 20 amp breakers?. Can I use 15 amp receptacles? Must I use side wiring? Can I even buy push-in back-stab for 12 ga anymore? This project involves 50+ new "decora" style outlets.
yojimboak is offline   Reply With Quote
Old 08-07-2012, 04:22 PM   #2
kevinp22's Avatar
#1 pretty much everyone around here is going to tell you that you should not use backstabbed receptacles - always use the screws
#2 You can use 15A rec on 20A circuit so long as that is not the only outlet on that circuit (sounds like that is not a problem for you)
part of your post did not work so I am sure I am answering everything.
Make sure you comply with rules related to tamper resistant and gfci receptacles as required
kevinp22 is offline   Reply With Quote
Old 08-07-2012, 04:36 PM   #3
Electrical Contractor
You will not find any back stab receptacles that will accept #12 wire, so you use the screws or pigtail everything.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-07-2012, 05:09 PM   #4
A "Handy Husband"
rjniles's Avatar
You can buy "back-wired" receptacles that will work with 12ga. wire
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-07-2012, 06:02 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
What type of "project" is this?
I'm not sure if they make back wired Decora style receptacles.
Speedy Petey is online now   Reply With Quote
Old 08-07-2012, 08:15 PM   #6
I know Leviton does make Spec Grade Decora Receptacles that have the back-wire capability. However, you're probably going to end up paying something like $5-7 a piece for those puppies.
LooseSCruz is offline   Reply With Quote
dimmer switch to duplex receptacle johneduffy Electrical 4 06-04-2011 09:12 PM
duplex receptacle with single pole switch in bathroom cangert Electrical 8 04-26-2011 08:14 PM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 08:51 PM
Is it acceptable to use push connectors AND screws on a duplex receptacle? Bob K. Electrical 5 03-07-2010 08:14 PM
