-   -   12 ga duplex receptacle (http://www.diychatroom.com/f18/12-ga-duplex-receptacle-152963/)
yojimboak 08-07-2012 04:19 PM
What can I use or not use in replacing old push-in back-stab receptacles on 12 ga wiring with 20 amp breakers?. Can I use 15 amp receptacles? Must I use side wiring? Can I even buy push-in back-stab for 12 ga anymore? This project involves 50+ new "decora" style outlets.
kevinp22 08-07-2012 04:22 PM
#1 pretty much everyone around here is going to tell you that you should not use backstabbed receptacles - always use the screws
#2 You can use 15A rec on 20A circuit so long as that is not the only outlet on that circuit (sounds like that is not a problem for you)
part of your post did not work so I am sure I am answering everything.
Make sure you comply with rules related to tamper resistant and gfci receptacles as required
jbfan 08-07-2012 04:36 PM
You will not find any back stab receptacles that will accept #12 wire, so you use the screws or pigtail everything.
rjniles 08-07-2012 05:09 PM
You can buy "back-wired" receptacles that will work with 12ga. wire
Speedy Petey 08-07-2012 06:02 PM
What type of "project" is this?
I'm not sure if they make back wired Decora style receptacles.
LooseSCruz 08-07-2012 08:15 PM
I know Leviton does make Spec Grade Decora Receptacles that have the back-wire capability. However, you're probably going to end up paying something like $5-7 a piece for those puppies.
