12/3 Wire With Ground - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-02-2011, 02:58 PM   #16
My kitchen is 8x12 & I have 3 SABC & a dedicated fridge circuit
It originally had only one circuit
Toaster = 850w, Microwave over 1100w, Toaster oven 1500w
Try running that on one 2400w circuit
Add in blender, a few crock pots, electric hot plate for breakfast & its impossible
You are not required to retrofit an older kitchen
But once you renovate yes you need 2 SABC
Its not about what you need or can get by with, its about what the next owner may need & whats required by code
Scuba_Dave is offline
Old 01-02-2011, 03:02 PM   #17
Master Electrician
Rewards Points: 3,756
Originally Posted by Sfeyelectric View Post
Again According to the NEC 2008 the kitchen countertops need 2 dedicated 20amp gfci protected circuits. NEC does not state only kitchens over a certain size.
If you were to have done a complete rewire you would have had to bring it up to that standard. You however have not done so and are not required to do such!
disregard
brric is offline
Old 01-02-2011, 03:07 PM   #18
Master Electrician
Well if it is being done to code as it should be. It must have 2 circuits serving the kitchen counter tops. We are here to encourage DIY's to do things in a professional and legal way, Thus we should only make recommendations as the code reads.
disregard.
brric is offline
Old 01-02-2011, 03:15 PM   #19
Rewards Points: 6,652
Not anyone is going to run all of those small appliances at the same time Dave. Show me someone that wants to do that, and I will show you how to start a fire with all of that load when the breaker fails. A 15 amp circuit will trip if you try to run a toaster and a microwave at the same time. A 20 amp circuit will trip if you try running a toaster, blender and Microwave, maybe lucky to run a toaster oven, or portable Dish Washer at the same time for maybe five minutes before the breaker fails with all of that load.
If it ever comes down when we go to sell the house, and the buyer is so wanting ACFI's and another GCFI to protect the circuit on the opposite side of the Kitchen, I may make that change, but for now, the one by the sink and the one on the opposite side of the Kitchen are sufficient, because the only one that would get used for a Toaster or Blender is to the Right of the sink. The one by the stove is there for convenience, same with the one behind the microwave for the portable Dishwasher & Microwave to plug in.
In the lines of what the OP is wanting to do, MWBC are great if wired correctly, and needing multiple circuits for GCFI protected it would work in this case. Running two separate circuits such as what they are wanting to do (GCFI & dedicated for a fridge) is not going to work, because as mentioned ,the GCFI does not like sharing the Neutral, same with ACFI's. If trying to do it with a ACFI protected circuit, it will not work, without tripping the ACFI when ever a load is placed on the line heavy enough. As mentioned before, you could plug in a small radio, the circuit may not trip, but plug in a heavy enough load on a ACFI circuit, it will fail.
gregzoll is offline
Old 01-02-2011, 03:16 PM   #20
Sfeyelectric's Avatar
Originally Posted by brric View Post
Please cite the code article refering to countertops.
Receptacles installed in a kitchen to serve countertop surfaces shall be supplied by not fewer than two small appliance branch circuits! 210.52(b)(3)
I was however wrong about dedicated because they can also serve other receptacles also!
Sfeyelectric is offline
Old 01-02-2011, 03:19 PM   #21
Master Electrician
You are correct I was looking at something else. Sorry.
brric is offline
Old 01-02-2011, 03:23 PM   #22
joed's Avatar
Rewards Points: 12,002
Other receptacles on the counter only, not in other rooms or serving lights under the cabinets.
joed is offline
Old 01-02-2011, 03:25 PM   #23
No problem buddy, posted before i seen your disregard.
Old 01-02-2011, 03:26 PM   #24
correct,
Old 01-02-2011, 03:26 PM   #25
Code states one thing, but feasibility is another when you do it in the real world. There is no way a 80 square foot Kitchen may warrant any more than one Small Appliance circuit, lucky to have one outlet only, but a larger Kitchen 100 sq foot or larger can warrant two or more Small Appliance circuits and more than one outlet per circuit. It comes down to semantics when you put it in a real world situation.
gregzoll is offline
Old 01-02-2011, 03:29 PM   #26
Code is a minimal standard. We should not instructed DIYers to do anything less than that.
Old 01-02-2011, 03:34 PM   #27
That's completely false
We run the toaster, toaster oven, hot plate & the microwave all together on a fairly reg basis
Sunday breakfasts are when everything is going all at once
No one wants to reset a breaker because someone renovated their kitchen & decided they did not need to meet the MIN standards of code
Old 01-02-2011, 04:06 PM   #28
That may be in your case, but in ours, we are lucky to run the toaster, which at the same time, would have the coffee pot on at the same time. Everyone's needs are different, and yes, the code is correct, but from feasibility, sometimes it makes no sense, especially in this case, where only one outlet is used all the time, and that is to the right side of my sink. I did make sure that if I ever decide to split the outlet to the left from the one on the right, all I have to do, is change it out in the junction box to add the second SABC if decided. The second outlet was only a addition to allow for power for the portable dish washer to not have to be pulled into the room.
It may change when we do the cabinets this Spring, since the wife wanted the electric done now, and not have only one outlet. In the case of the OP, I thought of using a MWBC in my case, which I could do, but from the headache point, it is not worth it, especially if the next person comes in, and starts messing with the junction box downstairs on the ceiling, and decides to feed 240 to the normally 120v circuit.
gregzoll is offline
Old 01-02-2011, 04:12 PM   #29
Its not a matter of what YOU use
Its a matter of what is required by CODE
Old 01-02-2011, 04:16 PM   #30
He is gonna keep arguing this. I just hope whatever field he is in, he makes sure his customer get a code complainant job!
Closed Thread
Tags
elecrrical line , electic warming , electical
What wire gauge for plumbing ground? bob22 Electrical 4 04-04-2010 08:01 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
