12-3 UF Cable With No Ground - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 07:28 PM   #31
Rewards Points: 242
Originally Posted by k_buz View Post
Upside down!
There is no upside down. whats the reasoning for the grounding slot on the bottom as compared to the way I have it??
Unless the plug going into the outlet is an immediate turn plug then doesnt matter
collegetry is offline   Reply With Quote
Old 08-08-2012, 07:29 PM   #32
Rewards Points: 242
Im going to watch Olympics. I'll let you guys keep repeating its upside down.
Old 08-08-2012, 07:30 PM   #33
zpm
yeah, right
Originally Posted by collegetry View Post
are you suggesting I paint it? why?
Or you can paint it gray.
If you don't and its in direct sun, it will turn a lovely shade of yucky purple brown. Of course by then it will match the crappy plastic cover which (if it hasn't been broken off) will be cloudy and scratched up.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-08-2012, 07:34 PM   #34
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Its just electrical humor... embrace it!!!
Old 08-08-2012, 07:37 PM   #35
Rewards Points: 242
crappy cover you think? Its not a home depot or lowes special. Its a Morris brand from a local supply house. What would you have suggested?
Old 08-08-2012, 08:04 PM   #36
E2 Electrician
I use taymac, they are all ugly.
Old 08-08-2012, 09:19 PM   #37
zpm
yeah, right
Exposed plastic doesn't last long in my area.
I prefer Genuine Cheap Chinese Lead Tainted Galvanized Steel.
(with a solid cover, nobody's gonna see if the ground is up or down)
The Following User Says Thank You to zpm For This Useful Post:
Missouri Bound (08-08-2012)
Old 08-09-2012, 07:23 AM   #38
Rewards Points: 242
Originally Posted by Missouri Bound View Post
The writing on the receptacle is upside down, right?
Missouri Bound I assume you like the Show Me State so I will show you. Heres a close up of the outlet I used. You tell me.
That's a clue as to how it is intended to be installed.
So by your logic ground slot up. Thank You.
Also next time you are in a hospital note which way the ground slot is positioned on the receptacles.
Old 08-09-2012, 07:25 AM   #39
Rewards Points: 242
I like it.
Now can we discuss which way the toilet paper should be, Over or Under??
Old 08-09-2012, 07:47 AM   #40
Master Electrician
Jobs with metal cover plates are often spec'd ground up so if someone removes the plate with something connected to the receptacle then the plate falls on the ground instead of across the power and neutral.
I know its stupid, why take a plate off with something plugged in, but i've seen it required on a lot of jobs.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-09-2012, 10:54 AM   #41
zpm
yeah, right
I like it.
Already been discussed.
http://en.wikipedia.org/wiki/Toilet_paper_orientation
And the answer is ... what the wife wants.
Old 08-09-2012, 12:02 PM   #42
Rewards Points: 242
Ever wonder why the words TEST and RESET are on the buttons of a GFI in both orientations??
Old 08-09-2012, 02:11 PM   #43
Missouri Bound's Avatar
Your picture is upside down......
Do you want it your way or the right way?
Old 08-09-2012, 06:39 PM   #44
Rewards Points: 242
deleted
Old 08-09-2012, 10:47 PM   #45
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I always thought that it was a signature as to whether you were installing in a commercial setting or residential ....
Ground up ..... commercial
Ground down ... residential
The only time in residential that I really think about it is if there is a cord device that will be plugged into the outlet that might be better oriented if the ground is up. Otherwise I put the ground down or I install the outlet side ways .... then it becomes ground left or ground right ....
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
running outdoor cable from house to detached shed above ground amakarevic Electrical 2 11-19-2010 02:16 PM
Can I ground an outlet via a cable jack? OhNevermindMe Electrical 7 04-15-2010 10:06 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Cable and telephone ground jerryh3 Electrical 12 06-16-2008 08:11 PM
