Old 08-06-2012, 09:42 PM   #16
Licensed electrician
12-3 UF cable with No Ground
The warmer the cable is the easier it seems to strip. I don't know if the older stuff is the same way.
Old 08-06-2012, 09:52 PM   #17
E2 Electrician
stickboy1375's Avatar
Ive never had good luck even with warmer temps... They certainly were not thinking of the installer when making this stuff back in the day, usually you will see it installed with the grey outer jacket still intact with maybe 1/2 an inch stripped just so they knew how to identify the conductors.
Old 08-06-2012, 10:35 PM   #18
Leave the new stuff in the sun and the outer sheath is like butter. You just need to make sure not to go too deep and into the conductor insulation. I skin from the outside in and peel the conductors out.
Old 08-06-2012, 10:52 PM   #19
E2 Electrician
I use the Klein brand, but i just use these on UF, works perfect.
Old 08-07-2012, 08:06 AM   #20
Originally Posted by stickboy1375 View Post
try to strip the UF BEFORE you insert it into the box, this should save you some aggravation.
that was on the agenda
collegetry is offline   Reply With Quote
Old 08-08-2012, 08:00 PM   #21
First broke up the concrete around the fence post, dug trench , ran UF in the trench, sleeved it in PVC stub up, installed box, outlet & in use cover, then mixed up a little concrete to replace what I broke up, The UF was not that bad to strip and I did strip it before feeding it into the stub up. Now waiting on the Arlington mounting block to arrive so I can finish with the outlet on the siding. T
Old 08-08-2012, 08:08 PM   #22
Missouri Bound's Avatar
SO..............are you going to paint that pipe white?
Do you want it your way or the right way?
Old 08-08-2012, 08:12 PM   #23
are you suggesting I paint it? why?
Old 08-08-2012, 08:15 PM   #24
Electrical Contractor
Receptacle is upside down!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-08-2012, 08:17 PM   #25
There is no upside down for a duplex receptacle. I always put the ground plug toward the top.
Old 08-08-2012, 08:18 PM   #26
E2 Electrician
JBfan knows... he is being a joker. And I agree, it's upside down.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (08-08-2012), Missouri Bound (08-08-2012)
Old 08-08-2012, 08:24 PM   #27
with the grounding slot on top, a falling metal object like a picture frame will bounce of a partially exposed plug with no harm done. With the grounding slot on the bottom, an object that falls on a partially exposed plug could short across the hot and nuetral blades of the plug.
Nothing hanging above this plug but thats my reasoning and the way I've done it inside the house.
Whats your guys reasoning for saying the grounding slot on the bottom?
And dont say because it makes a nice smiley face
Old 08-08-2012, 08:24 PM   #28
Licensed Electrician
k_buz's Avatar
Upside down!
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (08-08-2012)
Old 08-08-2012, 08:27 PM   #29
E2 Electrician
Yeah okay... any data on this theory? I would love to see a metal object being dropped against the wall to see how many times it falls towards the grounded conductor vs ungrounded conductor... lol....
nice job by the way, it came out perfect. Dont mind the upside down and rightside up jargon, its mostly just funny business.
Old 08-08-2012, 08:27 PM   #30
Not sure how an object is going to fall on a partially exposed plug under a weatherproof cover. The writing on the receptacle is upside down, right? That's a clue as to how it is intended to be installed.
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
running outdoor cable from house to detached shed above ground amakarevic Electrical 2 11-19-2010 03:16 PM
Can I ground an outlet via a cable jack? OhNevermindMe Electrical 7 04-15-2010 11:06 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Cable and telephone ground jerryh3 Electrical 12 06-16-2008 09:11 PM
