12-3 UF Cable With No Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 05:23 PM   #1
Rewards Points: 242
12-3 UF cable with No Ground
I'm running power around the perimeter of my patio to a receptacle to be mounted to a fence post. Going to use UF cable and sleeve it thru PVC conduit where it emerges from ground. To read further about this see this thread:
Outdoor weatherproof boxes with PVC conduit
A buddy had a roll of this "Cadillac 12-3 UF cable" with no ground. I can use this at no cost to me.
Can I use this and use the red as the ground and maybe just mark it with green tape?
Also what is a trick to stripping this stuff.
12-3 UF cable with No Ground-tt.jpg   12-3 UF cable with No Ground-ttretert.jpg
collegetry is offline   Reply With Quote
Old 08-06-2012, 06:06 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Technically no, but....
Old 08-06-2012, 06:16 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No, you can't... but I have to say, i've seen a ton of IG receptacles installed with a "RED" conductor taped green.
Old 08-06-2012, 06:16 PM   #4
E2 Electrician
I feel the same way.
Old 08-06-2012, 06:23 PM   #5
Rewards Points: 242
Not too technical around here so I understand. Now is there a trick to strip this beast?
Old 08-06-2012, 06:27 PM   #6
E2 Electrician
You may want to practice. But first off, use a brand new razor blade in your knife, this wire is OLD and I can guarantee you it is going to be a pain in your ass. what I do is take my blade and run it in between two conductors being careful not to get close to either conductor, then I just peel the outer jacket off, takes a little practice, but your wire is so old, you ARE going to battle.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (08-06-2012)
Old 08-06-2012, 07:12 PM   #7
Rewards Points: 12,882
You do know that outlet will need to be GFI, right?
Old 08-06-2012, 07:24 PM   #8
Rewards Points: 242
The outlet on the fence post will not be a GFI.
Old 08-06-2012, 07:25 PM   #9
It needs a GFI there or at the breaker.
Old 08-06-2012, 07:31 PM   #10
Rewards Points: 242
To follow up, the outlet on the fence post will be supplied power from an outlet being installed on the backside of the house. This outlet on the house will be a GFI so I'll load side that. here is the mounting block I'm going to install on the outside of the house. It has the box incorportated into it.
Old 08-06-2012, 08:00 PM   #11
Oso954's Avatar
Rewards Points: 444
Sometimes "free" costs more paying for it.
I think you need to put the old UF wire 24 inches deep.
I have really hard digging, so I would use PVC conduit the whole way, using THWN. If it is GFCIed, 120V, 20 amps or less, you can do it at 12 inches.
If the circuit ever fails, you can almost always re-pull it in conduit. With UF, you end up digging again.
If it's not hard digging, the moles and gophers get it, at least around here.
Oso954 is online now   Reply With Quote
Old 08-06-2012, 08:49 PM   #12
Rewards Points: 242
my first choice is PVC conduit with the individual wires pulled. My second choice is UF cable. Second choice wins out this rodeo.
Old 08-06-2012, 08:50 PM   #13
E2 Electrician
LOL, and since it was mentioned, GFCI protect the circuit and you only need a 12" trench. And as a heads up, try to strip the UF BEFORE you insert it into the box, this should save you some aggravation.
Old 08-06-2012, 08:52 PM   #14
Missouri Bound's Avatar
...and start with about 3 feet more wire than you need...by the time you get the stripping down it will be just the right length. UF is a b*tch to strip...the older the worse.
Do you want it your way or the right way?
Old 08-06-2012, 09:04 PM   #15
E2 Electrician
The new stuff is fantastic, I just use my NM strippers, and pull the entire jacket off, dont even use a razor anymore.
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
running outdoor cable from house to detached shed above ground amakarevic Electrical 2 11-19-2010 03:16 PM
Can I ground an outlet via a cable jack? OhNevermindMe Electrical 7 04-15-2010 11:06 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Cable and telephone ground jerryh3 Electrical 12 06-16-2008 09:11 PM
