12-3 / 2 Circuits CRAZINESS! HELP - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 12:29 PM   #1
12-3 / 2 circuits CRAZINESS! HELP
A friend recommended i run a single 12-3 UF wire to power a newly built pavillion to save $ on wire. I read a few articles explaining the seperate legs at the panel. I understand the necessity for positioning the breakers on seperate phases to accomodate the return of +18a/-18a when sharing a common neutral for two circuits.
WHY do i read 1.5 - 1.9 on the tester when i have it connected to the one breaker completely disconnected from the panel and in my HAND with the other breaker in the on position?
Out of shear curiousity i disconnected EVERY other wire from the sequence (even white and ground) to insure no crossing/crushing/crimping etc and still have the same reading
PLEASE HELP!
Hairy Homeowner
jasondelucia is offline   Reply With Quote
Old 09-01-2010, 12:57 PM   #2
Mad Scientist
Where are the two probes of your tester connected when you get this reading? You are probably just picking up a bit of phantom voltage induced from other nearby wires.
Also, your post makes it sound like you are using two separate breakers for this circuit. This is incorrect, a multi-wire branch circuit must use a double-pole breaker.
McSteve is offline   Reply With Quote
Old 09-01-2010, 01:33 PM   #3
Just call me Andrew
Rewards Points: 1,020
Or two single-pole breakers above one another, tied together with a handle tie.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
McSteve (09-01-2010)
Old 09-01-2010, 02:17 PM   #4
Mad Scientist
Thanks for that, I always forget that possibility.
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 12:22 PM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 08:45 AM
15A receptacle circuits in kitchen _in addition to_ 2x 20A? WaldenL Electrical 4 09-18-2009 05:58 PM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 07:00 PM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 09:21 AM
