12-2 Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 12:59 PM   #1
the Musigician
DangerMouse's Avatar
12-2 wiring question
How many 12g wires can I put under one big red wirenut and pass code?
I find I need 4, not 3 as I had thought at first. Is 4 OK?
Thanks, just double checking!
DM
Old 04-22-2010, 01:01 PM   #2
Electrician
Rewards Points: 802
Should say on the side of the container they came in if you have it, but 4 #12 will be fine with the red marrette.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
DangerMouse (04-22-2010)
Old 04-22-2010, 01:13 PM   #3
the Musigician
Thanks! There WAS a little tiny chart on the plastic package. I should have looked first, sorry.....
It says 2 to 5 for #12, up to 6 for #14!! (but only 3 for #10)
Wow, I'm imagining a hard time with 4 #12s..... don't think I want to try 5.
DM
Old 04-22-2010, 02:00 PM   #4
Electrician
Rewards Points: 802
Try 6 to 7 #10 solids and then 5 #12 would be easy for you.
The best way is to leave lots of bare copper when your stripping them, line up the jacket of the wire and slowly twist.
Old 04-22-2010, 02:03 PM   #5
the Musigician
Yup, I got 'em in fine. It was actually a little easier than I thought it'd be.
Box finished, on to the next project!
Thanks!
DM
Old 04-22-2010, 05:57 PM   #6
Rewards Points: 6,652
Really depends on your local inspector. Four #12 is pushing it, since that is the max the Red ones take. Blues will take 4-6.
Old 04-22-2010, 06:12 PM   #7
the Musigician
The package says max. 5 #12s in the red.
DM
Old 04-22-2010, 06:17 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
DM
If you are good, you can get 6, not that I have ever done that!
Old 04-23-2010, 08:39 AM   #9
NEC does not codify the number of wires a wire nut can take, and there doesn't appear to be an industry standard. This is one of those issues where code would say you follow manufacturers instructions. Even within a single manufacture, different style wire nuts of similar color can still have different specifications.
HooKooDooKu is offline   Reply With Quote
The Following User Says Thank You to HooKooDooKu For This Useful Post:
DangerMouse (04-23-2010)
Old 04-23-2010, 09:51 AM   #10
the Musigician
Very good point, thank you!
I called the inspector this morning on another matter, though I also asked on this. He said 4 is fine, though he prefers 3 with a pigtail. He also refers back to packaging specs. He says "If that's what the MFG. says is OK, I'M OK with it."
DM
Old 04-23-2010, 11:20 AM   #11
Here's a link to Ideal's catalog showing the various wire nuts with charts showing basic range of wire sizes covered by the different colors.
http://www.idealindustries.com/media...or_catalog.pdf
And for those of you who use the Ideal wire nuts, here's a great chart that basically lists every allowed wire combination for the various wire nuts. Really handy when you're mixing wire sizes such as wiring illuminaries.
http://www.idealindustries.com/media...mbinations.pdf
mini split Wiring question??? mjebril HVAC 5 08-02-2009 06:31 PM
Wiring question for camper wkheathjr Electrical 3 07-28-2009 04:15 PM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Quick wiring question with HVAC Gjtrafl Electrical 4 06-25-2009 02:03 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
