Old 04-21-2009, 08:11 PM   #1
Default 12/2 wire in contact with Hot water pipe (copper) - Dangerous?
Hi,
Recently ran some 12/2 wire for a dedicated 20a circuit from the basement to the attic, up past the cold air return. This is also where the hot and cold water pipes go from the basement to the second floor.
There's a possibility that my 12/2 wire is resting up against the copper hot water pipe.
(I took a picture, but the contact point is 5' away, difficult to determine from the picture alone, and this is in a spot where no man's head will fit, only my arm
Q:
What would happen if the 12/2 casing melted, and further melted through to the hot wire casing:
Would it ground out and trip the breaker?
*** Would it electricute someone if they were having a shower and the hot wire touched the copper pipe?
OR, have I asked a very stupid question?
AND is it impossible for the 12/2 casing to melt from something only as hot as my hot water pipes? (Note: my hot water tank is turned up to max temp)
Thanks again!
Tryvidy is offline   Reply With Quote
Old 04-21-2009, 08:19 PM   #2
Yes. You pipe may get to, what....170? It would take probably 300 to melt the plastic sheathing and even more on the wire insulation.
We try to avoid any contact with piping and ductwork, just to be extra safe, but the likelyhood of damage to the cable is nil.
Don't lose any sleep over it. Remember, your water heater has electrical wiring right in it.
You have smoke detectors and insurance....right
220/221 is offline   Reply With Quote
Old 04-21-2009, 08:25 PM   #3
Always Learning
You said past the cold air return, I suppose you mean not through it hopefully.
Even if somehow the hot touched the pipe, if its a metal connection to the meter, the breaker would trip if the pipes are bonded.
rgsgww
I think I'm addicted to this site...
rgsgww is offline   Reply With Quote
Old 04-21-2009, 08:33 PM   #4
Electrical Contractor
kbsparky's Avatar
12-2 is rated for 90 degrees Celsius which translates to 194 degrees Fahrenheit.
Real scalding hot.
I doubt your water pipes are that hot.
Old 04-21-2009, 08:39 PM   #5
Great, thanks for the speedy replies everyone!
rgsgww, correct, i ran the 12/2 beside - not in the cold air return.
Old 04-21-2009, 08:44 PM   #6
Extreme DIY Homeowner
Scuba_Dave's Avatar
Hot & cold water as in to sink etc?
Not hot water heating?
Many houses have a tempering valve after the Wh & temp is set to 120
I've yet to see a house where the WH temp is set over 140 without the tempering valve - you burn your hands off
Old 04-21-2009, 09:35 PM   #7
Bigplanz's Avatar
334.15 (B) would tend to lead me to believe that the romex should be in conduit, as specified. It is passing between floors, correct? Even if it wasn't passing through a floor, I would think that a cable in direct contact with a hot water pipe would trigger the need for 'physical protection,' as per this section.
334.15 (B) Protection from Physical Damage. Cable shall be protected from physical damage where necessary by rigid metal conduit, intermediate metal conduit, electrical metallic tubing, Schedule 80 PVC conduit, or other approved means. Where passing through a floor, the cable shall be enclosed in rigid metal conduit, intermediate metal conduit, electrical metallic tubing, Schedule 80 PVC conduit, or other approved means extending at least 150 mm (6 in.) above the floor.
Bigplanz is offline   Reply With Quote
More On This Topic
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
Learn how to grind metal parts smooth when doing body work and restoring a car in this free DIY car-restoration video from our expert mechanic and body shop owner. Read More »
Hi, on behalf of Exert Village I'm Terry and today I'm going to show you how to use a set of metal nibblers in metal working. Ok now I found a piece of expanded metal out back that I can use for my centerpiece. I'll trace it like that and I'll get a... Read More »
Hi, I'm John Sexton on behalf of Expert Village. Today we're going to be learning how to play Portal, a game by Valve Software. A company with which I have no affiliation. All right! Here we are in test chamber 08. We've got some new icons here now. We... Read More »
Hello, my name is Mac and on behalf of expertvillage.com I would like to discuss tripping hazards in a welding shop. Now a lot of welding shops have a lot of weld cables, hoses for air tools, extension cords for electrical tools and very often they are... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
How To Solder Copper Pipes thekctermite How To Guides 65 11-04-2009 10:14 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 10:09 AM
electric cable crossing (hot water) copper pipe amakarevic Electrical 4 09-17-2008 06:10 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 01:05 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
