12/2 Vs. 12/3 - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 01:29 PM   #1
12/2 vs. 12/3
I'm doing a wiring project and need some advice on what type of wire to purchase. I'm basically going to tap into an existing 20 amp circuit outlet in the kitchen to install an extra outlet. I need to do this as I am moving the refridgerator and installing an over the range microwave.
The cost of the wire is not a concern for me. My basic question is if I can just buy 12/3 wire, even though I probably won't need the extra hot wire? Can I do this and just not use the extra hot wire?
Also, for what I am doing will 12/2 wire be enough? Actually, I'm pretty sure that it will be enough, but I wanted to know if 12/3 is also fine to use and is just overkill.
Any advice would be greatly appreciated.
Thanks - Joe
Suncrest79 is offline   Reply With Quote
Old 03-07-2009, 01:35 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
Joe,
I am not an electrician but from my understanding you can use 12/3 and cap off the red wire at both ends. If in the future you need a 240 volts appliance installed you can use this 12/3 wire and use the red. I guess the short answer is YES and cap off the reds. 12 gauge for 20 amps is correct. Remember that you can not tap from the kitchen if the power to new receptacle is to be used outside the kitchen which I do not believe is your case.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 03-07-2009, 02:42 PM   #3
bocolo you seem like your somewhat knowledgable-im a newb and posted a question in the forums.if you dont mind, check it out-nobody seems to know the answer..(sorry to invade another thread with my question.)
Electricnewb is offline   Reply With Quote
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
Question: Is using 12/2 wire, ok on 15amp breaker/outlets? ehoez Electrical 3 07-14-2008 07:41 AM
How can I use my 12/3 w/G ?? bradsguns Electrical 1 07-10-2008 10:20 AM
12/2 diameter question mark942 Electrical 5 04-18-2008 10:25 PM
Moving from 12/2 to 14/2 bbarnhart Electrical 4 12-04-2005 06:26 PM
