Old 10-08-2012, 05:55 PM   #1
12/2 vs 12/3
Silly question. Found that my electric fire alarms are wired with 12/3 with a ground. Not a 12/3 in my breaker box, so I'm assuming it is branched off of something else. The alarms are no good (won't go into detail) but will replace with plain battery operated ones. Can I just cap of the wires and put a cover plate on without it affecting whatever it is branched off of?
Savinmoney is offline   Reply With Quote
Old 10-08-2012, 05:58 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
12/2 vs 12/3
No. Replace them with what's there.
12/3 or 14/3 is typical between smoke detectors.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Savinmoney (10-08-2012)
Old 10-08-2012, 06:03 PM   #3
Pure Genius
12/2 vs 12/3
Its 2 wire to the first smoke and then 3 wire to the other devices. Also here in OH i have to tie smokes onto a bedroom circuit. Its a building code thing not an NEC thing
Dierte is offline   Reply With Quote
The Following User Says Thank You to Dierte For This Useful Post:
Old 10-08-2012, 06:15 PM   #4
12/2 vs 12/3
Thanks guys. It just threw me off seeing 12/3. I have 4 alarms... two that I peeked at. I'm sure one of the other two must be a 12/2 tied into a bedroom circuit. Makes a lot of sense now! Thanks again!
Old 10-08-2012, 10:07 PM   #5
12/2 vs 12/3
You will need the third wire in the cable to properly connect the smoke detectors to each other. You only need 2 wires to provide the power.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 10-09-2012, 10:23 AM   #6
12/2 vs 12/3
The 3rd wire is for the "interconnect" between alarms, which is what makes all of them sound at once.
patented is offline   Reply With Quote
The Following User Says Thank You to patented For This Useful Post:
Savinmoney (10-10-2012)
Old 10-09-2012, 02:11 PM   #7
12/2 vs 12/3
Replacing a hard wired system with battery operated is like taking air bags and shoulder belts out of your car to use a lap belt.
Hard wired (and interconnected) with battery backup is the way to go.
Oso954 is offline   Reply With Quote
The Following 3 Users Say Thank You to Oso954 For This Useful Post:
jbfan (10-09-2012), Savinmoney (10-10-2012), Speedy Petey (10-09-2012)
Breaker Panel Replacement Plan jillers Electrical 24 01-28-2012 11:12 AM
pulling a 12/2 run from 12/3, how to? SocalPaddy Electrical 23 10-24-2011 02:15 AM
Replacing 12/2 with 12/3 behind wall iya Electrical 8 06-20-2010 08:51 PM
Afci & 12/2 golddog Electrical 11 12-10-2009 12:23 PM
12/2 vs. 12/3 Suncrest79 Electrical 2 03-07-2009 03:42 PM
