12/2 NM Cable In 1/2" EMT Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 01:49 AM   #1
Rewards Points: 1,062
Question
12/2 NM cable in 1/2" EMT conduit
does 12/2 romex require a 3/4" EMT conduit? seemed kindof tight when i was driving it through 1/2"...
Old 11-15-2011, 02:58 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,970
Why are you trying to put NM cable in conduit? I can only think of one circumstance where that would be a good idea: protecting the cable running down the walls of a basement or garage. For such short straight lengths, 1/2" should be easy. What are you trying to accomplish?
mpoulton is offline   Reply With Quote
Old 11-15-2011, 07:11 AM   #3
Some local codes require that basements be piped and Romex drops need to be sleaved. It's very common to see Romex in conduit where I live, and the bigger the pipe the easier it is to do!
Colomboj is offline   Reply With Quote
Old 11-15-2011, 12:50 PM   #4
i have an exposed brick wall on which i mounted a receptacle... much easier than running wire through brick, no?
Old 11-15-2011, 02:38 PM   #5
liscenced electrician
Rewards Points: 538
I would probably use 3/4 if there were any bends. Nmb doesn't like to bend
jimmy21 is offline   Reply With Quote
Old 11-15-2011, 02:59 PM   #6
Obviously brick is hard to fish thru or impossible. If this is an interior wall you might consider plug mold instead of emt as it tends to look less industrial.
The Following User Says Thank You to Colomboj For This Useful Post:
jimmy21 (11-15-2011)
Old 11-15-2011, 05:11 PM   #7
As long as it's an interior installation, you're fine. You might want to consider just doing the whole installation in conduit with individual conductors.
Old 11-16-2011, 02:33 PM   #8
I would use 3/4" because 1/2" is very tight for 12/2.
Is this an exterior brick wall? If yes, you need to run UF or individual THWN even if in conduit. NM Romex is not rated for use in wet conditions.
brgmgb is offline   Reply With Quote
Old 11-16-2011, 02:42 PM   #9
it is inside but the other side of the wall faces outside. thanks
Running cable in conduit Audiotekm Electrical 10 11-09-2011 10:46 PM
Conduit for cable and phone brjl Electrical 6 04-05-2011 07:51 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Running 6/3 cable-do I need conduit? Kips Electrical 6 01-16-2009 11:36 AM
How many wires in 1/2" conduit? alvanos Electrical 17 02-26-2008 03:37 PM
