12-2-2 Wire Use ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 04:22 PM   #1
12-2-2 wire use ?
Hello,
I read through all of the posts and replies to this thread and I would like to know if I were to use a 12/2/2 romex wires to supply 4 individual circuits to my second floor would I still need to use a double pole breaker? Are there other special considerations that I need to follow when using 12/2/2 for barch circuits? I need to run 4 new circuits to second floor and I wanted to save some time running only 2 12/2/2 cables instead of 4 12/2 cables. Is this approach acceptable by the code? I will be using the circuits for the following: 1 dedicated for the bathroom, 1 dedicated for an attic fan, 1 for lighting 2 bedrooms, and 1 spare for future use. Thanks,
ericm215 is offline   Reply With Quote
Old 01-01-2011, 04:34 PM   #2
Rewards Points: 330
if you use 12-2-2 you will have 2 hot and two neutrals.red wire neutral has a red stripe.the one for the black is just white.and they don't need a two pole brkr.beacause each has its own neutral.should not be any issues.
oleguy74 is offline   Reply With Quote
Old 01-01-2011, 04:42 PM   #3
Originally Posted by ericm215 View Post
Hello,
As long the neutrals are not shared between the circuits (only bonded to the neutral bus in the panel), you do not need to use a double-pole breaker with 12/2/2. You will need to keep an eye on junction box capacity, however, since the number of conductors will increase.
Keep in mind that there is a difference between 12-4 and 12-2-2. 12-4 contains black, red, white and blue and is intended for 3-phase application, while 12-2-2 contains red, black, white and white/red stripe. You need to use 12-2-2, as the neutral must be coded white.
clashley is offline   Reply With Quote
The Following User Says Thank You to clashley For This Useful Post:
ericm215 (01-01-2011)
Old 01-01-2011, 11:13 PM   #4
Electrical Contractor
kbsparky's Avatar
Originally Posted by clashley View Post
.... Keep in mind that there is a difference between 12-4 and 12-2-2. 12-4 contains black, red, white and blue and is intended for 3-phase application, while 12-2-2 contains red, black, white and white/red stripe.....
While 12-4 and 14-4 may be used on 3 phase circuits, we routinely use it for single phase circuits, such as carrying a hot, neutral, and 2 travelers on 3-way switching schemes. Or multiple switch legs for things like heat/fan/light units in bathrooms, etc. Having that extra blue conductor in there is really helpful in many instances.
I would also use it for 2 circuits on a single homerun where one circuit would feed the electric heat (240V red-blue), and the other one would pick up the receptacle outlets in the same room (120 AFCI protected black-white).
-KB
Old 01-03-2011, 08:20 PM   #5
Thanks everyone for the great advice!!!
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
