12/2 On 15 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 09:22 PM   #1
12/2 on 15 amp circuit
Hi Everybody!
I have a 3-way switch that controls a light; all of the current wiring is 14/2 (and 14/3 for the 3-way part).
I plan on replacing the single light with multiple recessed lighting cans... my question is:
Can I use 12/2 from the switch to the new lights even though the power source to the switch is 14 gauge wire?
Thanks,
Ed
monkeystomach is offline   Reply With Quote
Old 02-20-2011, 09:26 PM   #2
joed's Avatar
Rewards Points: 12,024
Yes. The circuit must be protected by 15 amp breaker or fuse since you have #14 on the circuit.
Old 02-20-2011, 10:04 PM   #3
Rewards Points: 212
Maybe in Canada its ok to mix wire, but not in the US. If a part of a circuit is 14 gauge the whole circuit should be 14 gauge. 15 amp is an appropriate size breaker for 14 gauge
bluebird5 is offline   Reply With Quote
Old 02-20-2011, 10:37 PM   #4
joed's Avatar
It is perfectly OK and to code to use #12 wire on a 15 amp circuit under the NEC.
Old 02-21-2011, 01:50 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
you can always over size a wire for a given breaker size, but never under size.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-21-2011, 07:25 AM   #6
Rewards Points: 1,216
"That's what the answers were, DUH!!"
COLDIRON is offline   Reply With Quote
Old 02-21-2011, 03:05 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
As far as 12 ga on a 15A circuit...sure you can. One suggestion is to put a tag on the 12ga wire stating "15 amp circuit" where the wire is accessible...just to let others know in the future.
Kyle
Old 02-21-2011, 04:42 PM   #8
Rewards Points: 212
it is not about whether you can put 12 gauge wire on a 15 amp breaker. sure its ok if the whole circuit is 12. the fact is that you have a 14 gauge coming in and a 12 gauge going out. why would you have a small wire feeding the curcuit and a large wire pulling from hte smaller wire?
Old 02-21-2011, 05:15 PM   #9
Rewards Points: 530
Have some left over 12 around?
Old 02-21-2011, 05:31 PM   #10
Rewards Points: 212
I just think it sounds like the work of a hack. No professional electrican would just put whatever they wanted
Old 02-21-2011, 05:57 PM   #11
joed's Avatar
It may not be the ideal situation but it is legal and to code to do it.
Old 02-21-2011, 07:12 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Go on a service call, you only have the larger wire on the truck, you make it work.
I have used 12/3 for a 12/2 circuit, and in a pinch used a 3 way switch for a single pole.
Old 02-22-2011, 01:17 AM   #13
Scared Electrician
often done for voltage drop.
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 10:14 PM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 01:41 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
