Old 11-24-2006, 11:50 AM   #1
12/2 15 or 20 amp
I know that code in NJ requires 12/2 wiring for outlets with that being said...do you need to have a 20 amp breaker for the outlets and do you also need a 20amp outlet. Can you mix & match outlets Exp: 20 a breaker some outlets 20 amp & other 15 amp..
TonyD
TonyD is offline   Reply With Quote
Old 11-24-2006, 11:57 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
12/2 15 or 20 amp
Are you sure about this code requirement? That is one I never heard for NJ.
If you are using #12, use 20 amp breakers. Period. There is NO reason to use 15's.
The only exception would be if the circuit is VERY long, like over 125' or so, and will be heavily loaded. Like for use with an iron or vacuum.
As long as there is at least one duplex receptacle on the circuit you can use 15 amp rated receptacles. There is no reason to use 20 amp rated receptacles unless you have a specific appliance that requires one, which is extremely rare.
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 06:53 PM
GFI Breaker & pool pump mitchman333 Electrical 7 05-08-2006 06:32 PM
Moving from 12/2 to 14/2 bbarnhart Electrical 4 12-04-2005 07:26 PM
