12/2 Or 14/2? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2010, 11:07 AM   #1
Rewards Points: 111
12/2 or 14/2?
Is there any benefit to running 12/2 for everything? I bought a house and it seems a lot of the wiring is 12/2. Should I stick with the 12 gauge when extending to some new recessed lighting I am installing or should I jump off the existing 12 with 14 gauge (is that even legal?)?
Any help is much appeciated
luvdairish is offline   Reply With Quote
Old 08-21-2010, 11:11 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Stay what the conductor size is allready run so if you have 4.0mm˛ { #12 AWG } so stay with it and they will work fine with 20 amp breaker however a nice gotcha yeah you can use 15 amp breaker as well but normally I resved that for long runs only.
Do not use 2.5mm˛ {#14 AWG } with 4.0mm˛ there due they are only rated at 15 amp max.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Proby (08-21-2010)
Old 08-21-2010, 11:28 AM   #3
Electrician
Proby's Avatar
Yup, you can't run #14 wire on a 20A circuit, even if it's only for one light.
As for running all #12, I have been doing that more and more lately.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-21-2010, 12:25 PM   #4
Rewards Points: 111
Sorry should have mentioned tn this case, the circuit is 15amp. Is it still ok to use 12 with a 15amp?
Old 08-21-2010, 12:34 PM   #5
Yes you can still use #12 with a 15a breaker
Old 08-21-2010, 12:50 PM   #6
Yep you can use 15 amp breaker with 4.0mm˛ cable that is not a issue at all but just make a note on the breaker box what that goes.
Merci.
Marc
Old 08-21-2010, 02:13 PM   #7
Rewards Points: 867
"Is there any benefit to running 12/2 for everything?" - you only have to keep track of one wire size for all branch ckt's, except for dedicated loads of course.
TimPa is offline   Reply With Quote
Old 08-21-2010, 04:52 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Yes, but under normal circumstances (such as not extremely long circuits) it make NO sense to use #12 on a 15A breaker. If it is all #12 use a 20A breaker.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (08-21-2010)
14/2 vs. 12/2 questions sanny651 Electrical 7 03-06-2010 10:52 PM
12/2 wire in contact with Hot water pipe (copper) - Dangerous? Tryvidy Electrical 6 04-21-2009 07:35 PM
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
Using 14/2 wire on 20 amp circuit mohairy Electrical 1 12-29-2007 06:26 AM
Moving from 12/2 to 14/2 bbarnhart Electrical 4 12-04-2005 06:26 PM
