12 And 14 Gauge Wire On One Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 08:17 PM   #1
12 and 14 gauge wire on one circuit
Hey:
We have a 20 amp dedicated circuit upstairs that only serves a small A/C unit (4.2 amps) and is really overkill. The cable is in a perfect location for me to tap into for an outside motion light and switch. I really prefer using #14 cable for several reasons.
Is it OK to splice into this #12 cable provided of course I switch out the breaker to a 15 amp breaker?
Thank you
whatrymes is offline   Reply With Quote
Old 04-16-2011, 08:22 PM   #2
Rewards Points: 1,536
Yes you can mix 12 and 14 gauge wire with a 15 amp breaker on the circuit.
But it is not recommended because the next homeowner or electrician may be confused and put a 20 amp breaker on it again.
Confusion can be reduced if, down in the panel, you splice on a short length (pigtail) of 14 gauge wire to the incoming 12 gague wire in order to attach to the breaker. Also put a label on that circuit wire.
It would be much better to add on using 12 gague wire since there is no telling whether more electricity won't be used on that circuit in the future.
Old 04-16-2011, 10:35 PM   #3
I agree with the previous poster. Just use 12 gauge wire and you won't need to worry. It isn't recommended to connect 14 to 12 as 14 wire isn't meant for 20 amp breaker. Its max load is 15 amps.
Clumsy Hamster is offline   Reply With Quote
Old 04-16-2011, 11:07 PM   #4
" Euro " electrician
frenchelectrican's Avatar
This done quite few time but myself I rather run all the rest the same size as exsting conductor if possable but if have to downsize the conductor for some reason then you have to mark it at the load centre to forwarn that it have diffrent conductor in there.
It the same way I do with oversized conductors I mark them down to warn them it is used for long run to deal with voltage drop.
Merci,
Marc
Old 04-17-2011, 09:32 AM   #5
Merci,
Marc
Good point Marc, thanks. I'll think on it some more.
Wire Gauge for 30A RV Outlet (long span) jayne1986 Electrical 24 02-20-2011 08:18 PM
use neutral wire from another circuit? justinm001 Electrical 9 07-27-2010 05:52 AM
What wire gauge for plumbing ground? bob22 Electrical 4 04-04-2010 07:01 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 12:55 PM
