110V Receptacle Bad? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 06:35 PM   #1
Rewards Points: 1,062
110V receptacle bad?
I wired up, a combination light switch-plug receptacle (probably anothr name for this), and I get no voltage on the 2 slot plug part. Light switch works to turn on light, though. Man, is it possible to have a bad one even new?
Thaks!
noquacks
noquacks is offline   Reply With Quote
Old 07-14-2010, 06:38 PM   #2
Soulda explained that yes, I did follow wiring directions for this type of hook up. I connected the hot from source to golden brass looking screw, hot lead going TO light unit went on left side, of switch (also brassy colored screw). Neutral wires got twisted, and one of them went into other side of 2 slot plug, of course.
tab on hot side serving both switch and receptacle remaining intact. Seems like I did it right, people?
Old 07-14-2010, 06:48 PM   #3
Sounds like you have a bad neutral.
hayewe farm is offline   Reply With Quote
Old 07-14-2010, 07:13 PM   #4
thanks, farm, but what does that mean? bad neutral at the unit itself or bad neutral WIRE? If bad wire, why does my light work?
Old 07-14-2010, 08:10 PM   #5
Rewards Points: 1,538
We cannot rule out a defect in the switch/receptacle unit.
Turn off the power. See if you can measure continuity (near zero ohms) between the neutral slot (the larger slot) in the receptacle and anywhere on the outside, notably a silvery screw.
Old 07-15-2010, 04:48 PM   #6
Wow! Thanks, Allan! let me go do that...maybe in the next hour.....
Old 07-16-2010, 04:45 PM   #7
Well, got rained out yesterday, but just checked it and man, I dont believe it, it works fine!!!!! Not sure what happened, but hey, thanks, people!!
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 08:10 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
