110v Outlet From 220v Line - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 02:47 PM   #1
110v outlet from 220v line
I have a 220v line that runs to the end of a dock (it runs a boat lift). I would like to put a 110v light out there as well. Can I take one leg of the 220v and use it to run the 110v light? The boat lift and the light will not be on at the same time.
Thanks,
emstype is offline   Reply With Quote
Old 06-26-2011, 02:54 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks,
The light needs a neutral (white wire).
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-26-2011, 05:15 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,990
Thanks,
You can only do this if it's a 4-wire circuit, i.e. there's a neutral wire present. Otherwise no. If there is no neutral, then you have two options for installing a light: either use a small transformer to step 240V down to 120 to run the light, or use a 240V light. If you use a fluorescent, metal halide, or sodium fixture, you can easily choose one with a 240V ballast. That's the simplest solution.
mpoulton is offline   Reply With Quote
Old 06-26-2011, 06:56 PM   #4
Electrical Contractor
kbsparky's Avatar
I'd opt for a small control transformer for the light. Using an LED or CFL light would not need many watts, and something as small as a 40VA control transformer would be sufficient for such a light.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
frenchelectrican (06-27-2011)
Old 06-27-2011, 12:58 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I was going to suggest that one as well but that work very well.
Merci,
Marc
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing 220V to 110V (hardwired) for an electric to gas cooktop switch. charleyhart Electrical 14 01-15-2011 01:12 AM
convert 110v to 220v Hayseed Electrical 4 12-01-2010 07:30 PM
220v vs 110v Baseboard Heater?? Master Brian Electrical 8 11-19-2010 11:13 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 10:46 PM
