110 Volt Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 06:40 PM   #1
110 volt subpanel
Hello
I have a 110 v leg coming off a 220 breaker. Can I take this 110v leg and use it to service a new 110v subpanel?
Thx in advance
igd101 is offline   Reply With Quote
Old 11-24-2011, 08:29 PM   #2
not legally
jammin06 is offline   Reply With Quote
Old 11-24-2011, 08:37 PM   #3
Missouri Bound's Avatar
Originally Posted by jammin06 View Post
not legally
EXPLAIN PLEASE
Old 11-24-2011, 09:50 PM   #4
I don't know about the legal stature of this but one thing also though -
While the main panel can connect the ground and neutral into the same tie-in, this tactic cannot be done at sub-panels. It does have to have it's own ground running to the main panel and not a neutral-ground tie-in.
I am no expert on all this but just look into that.
AnErin is offline   Reply With Quote
Old 11-24-2011, 10:56 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Originally Posted by igd101 View Post
Hello
Thx in advance
No, not without a lot more description of this situation.
What is the "leg"?
What size wire?
What size breaker?
What is the other half of the breaker doing?
Where will the sub-panel be?
Old 11-25-2011, 06:46 AM   #6
Petey
the "leg" is off a 30amp breaker going out to a dock.
12-2 wire "leg" off 30 amp double breaker presently running to a GFIC's
the subpanel would be to service the GFIC and lights
Old 11-25-2011, 07:37 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Where does the other leg go?
You can not use 12/2 on one leg of a 30 amp breaker.
You either need to change the wire to #10, or change the breaker to 20 amp.
If you do not need the 2 pole breaker, change it out to two single pole breakers of the corrct size.
jbfan is online now   Reply With Quote
Old 11-25-2011, 07:48 AM   #8
let me try to give more details
i have a 220v double breaker that feeds a boat lift
near by there is a 110volt box which feeds 2 GFIC outlets....when i turn off the double breaker dock feed, the 110 v GFIC outlets go off also....not good!
Can i take this line that feeds the GFIC and put a subpanel before the GFIC's?
Old 11-25-2011, 08:53 AM   #9
NO! The 240v line is feeding the 240v boat lift, as well as the receptacles. This is why everything goes off.
IMO this sounds like a handyman special death trap:
- 12/2 on a 30A breaker, especially considering the potential distance which makes it that much worse.
- 120v and 240v loads on a 12/2, which means the bare ground is carrying current. Fun times when there is a break in the ground and ALL metal parts associated with this system become live. Nice when you are outdoors, on the wet grass, by the wet lake.
Sorry, until you have an electrician out to evaluate this mess I am done.
Old 11-25-2011, 12:42 PM   #10
Rewards Points: 1,418
The existing 120 volt GFCI receptacles should have had a neutral and a maximum of 20 ampere breakering (overcurrent protection). A 240 volt only circuit with two current carrying conductors and ground may not serve 120 volt loads with or without a GFCI.
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 02:38 PM
Wiring Subpanel off Subpanel brgmgb Electrical 2 08-29-2011 05:18 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
